*Indel-B Fridge/Freezer GROUP BUY AND BS THREAD!!!**CLOSED
Discussion in 'Closed Group Buys' started by .45 JHP, Jan 7, 2016.
  1. Feb 22, 2016 at 7:28 PM
    #1141
    Leppz
    Leppz Well-Known Member
    Vancouver, BC
    2014 DCLB Sport Premium
    So I finally had the time to take a good look at this mounting plate. At first I had no idea how this thing was suppose to work. I tried prying it off the bottom and it was extremely tight. To the point that I thought I was going to break something. So I decided to unbolt it. The "bolts" kept spinning so it was a little difficult but I managed. After the nuts came off I then took out the small screws that held the mounting brackets and bolts/pins to the fridge. After I got one off I realized the problem right away. It is suppose to be a quick release system but the brackets that hold the bolts/pins are way too tight. I had to jam a screw driver into the mounting bracket just to get them out. I tweaked them a bit with a pair of needle nose and pliers so that they weren't as tight. Put everything back together and I can now can pop the fridge off the plate without feeling like I'm going to break something.
    Here's some pics
    Top is factory, bottom is what I tweaked them to. The brackets were way too tight to work effectively. Just keep popping the mounting plate on and off and keep tweaking the mounting brackets until you get a good tight hold without feeling like you're going to rip the fridge apart when pulling it off.
    Now that I've got this plate figured out I think I'm definitely going to incorporate it into building my own fridge slide.
    Fifthwind likes this.
  2. Feb 22, 2016 at 7:56 PM
    #1142
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    ah perfect! i still havent had a chance to look yet, so thanks for doing all the work first! glad to know its actually usable with a little fine tuning! im planning on eventually building a slide with it as well, but i have another plan i want to try first.
  3. Feb 22, 2016 at 8:21 PM
    #1143
    .45 JHP
    .45 JHP [OP] Doesn't even own a Tacoma
    37.3582115,-121.9281197
    2015 4Runner TRD Pro
    3.5 hours left to order :goingcrazy:
  4. Feb 22, 2016 at 8:24 PM
    #1144
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    How much do you charge to deliver a case of Pliny to mod day?
  5. Feb 22, 2016 at 8:26 PM
    #1145
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    pmd
    916TacoTruck[QUOTED] likes this.
  6. Feb 22, 2016 at 10:50 PM
    #1146
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Yes, that's one of my main worries.
    The lows will be in the 20s and 30s... So probably won't be doing it this time.
  7. Feb 22, 2016 at 10:55 PM
    #1147
    Stig
    Brandon
    Ta no mo
    Set up my thermometer.. I like it with the dual displays. I added a little divider to see if i can get the dual Temps working well. Might have to make a basket type thing just for the top half/fridge area since it seems like there's a lot of cold coming from the sides.
    It's currently cooling down to - 2 per the control panel and so far the bottom is at - 1 and the upper half of the main compartment is at 13
  8. Feb 23, 2016 at 6:23 AM
    #1148
    Stig
    Brandon
    Ta no mo
    Left the fridge at a set point of -2 overnight with the divider in (1/2" thick styrofoam insulation about 4" under the max fill line with 1/2" gap between it and the walls, and also made little walls above that, just propping it up on the basket thing thats in there and still staying below the max fill line). The display on the fridge shows 00 and the thermometer is reading 11 in the bottom and 22 up top. So the divider seems to be messing with the thermostat.
    As soon as I removed it, it fired up and started dropping the temp. Its plugged into 120v and is on max.
    The research continues.
    It bumped up to 13 at the bottom after I had it open to pull out the divider, and is now already back down to 5 and dropping, so the fridge clearly did not like the divider.
    But I threw the probe into the small compartment by the light and that temp is holding steady at 27.
  9. Feb 23, 2016 at 6:39 AM
    #1149
    Stig
    Brandon
    Ta no mo
    And another edit... -1 in the bottom and 26 in the small compartment.
  10. Feb 23, 2016 at 6:48 AM
    #1150
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    my fridge will be here before 3pm today :woot: :goingcrazy:
    Stig likes this.
  11. Feb 23, 2016 at 10:12 AM
    #1151
    ChamYota
    Cam
    Thanks for setting the gb up OP
    Leppz likes this.
  12. Feb 23, 2016 at 10:28 AM
    #1152
    Leppz
    Vancouver, BC
    What size is that? 41?
  13. Feb 23, 2016 at 10:41 AM
    #1153
    ChamYota
    Cam
    51
  14. Feb 23, 2016 at 11:27 AM
    #1154
    Stig
    Brandon
    Ta no mo
    43 it says it right on the display. :hattip:
  15. Feb 23, 2016 at 11:50 AM
    #1155
    ChamYota
    Cam
    :spy: it's reading like 20* but for what I'm gonna use it for idc as long as my food stays cold lol
  16. Feb 23, 2016 at 1:34 PM
    #1156
    Leppz
    Vancouver, BC
    Ah, the angle of the picture is deceiving. It looks smaller. I thought you were the first to post a picture of a 41L model.
    ChamYota[QUOTED] likes this.
  17. Feb 23, 2016 at 3:43 PM
    #1157
    .45 JHP
    That looks pretty cool. Where did you find it?
    I'm planning on running 14G wiring too...would that be enough to handle the fridge without any issues?
  18. Feb 23, 2016 at 3:49 PM
    #1158
    kbraunphoto
    kbraunphoto mountain bike haulin' & off camping
    Kevin
    Atlanta, GA
    '15 Inferno Orange TRD Pro
    Just a few expensive & DIY things...
    I updated one of my posts because I forgot the link, can't find it yet but here ya go:
    [plus it's in the bottom products discussed section now btw]
    http://www.amazon.com/dp/B00WLFU7QY
    When I first added it to my wishlist it was around $9.27, it fluctuates in price.
  19. Feb 23, 2016 at 4:22 PM
    #1159
    ChamYota
    Cam
    So is it possible to fit 2 batteries in the stock location? I already have one and im not sure if i can fit another of the same kind.. especially the AGM one
  20. Feb 23, 2016 at 4:25 PM
    #1160
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    ATO makes a battery box for dual Yellow Tops in the stock location.
