Independent offroad lights
Discussion in 'Technical Chat' started by LonghornTaco, Oct 17, 2008.
  1. Oct 17, 2008 at 9:02 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Ok, I'm trying to wire up my lights and I want to operate them independently of the headlights. I also want to be able to turn them on without the truck being on. Do I still have to run a wire to the headlights? I can't seem to get them to work...
    I bought Hella 500FF lights.
  2. Oct 17, 2008 at 9:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nope...dont have to wire them to the head lights. 2 wires from the switch....one to hot on lights, one to positive on abttery, with a fusible link, then the ground on the lights, bring them to the ground on the battery. this is with no relay either. wired lights like this alot...never had any problems....just dnt forget to turn them off.
  3. Oct 17, 2008 at 9:21 PM
    LonghornTaco
    Minnesota
    Check out this link: http://www.hella.com/produktion/HellaUSA/WebSite/Channels/Drivers/FAQs/FAQs.jsp
    Check out the Basic Wiring Diagram. This is what I have. I have run the wires like this (except the green one) and none of it is working...
  4. Oct 17, 2008 at 9:23 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    you should have a hot wire off the battery to the switch (with a fuse somewhere)...then a ground from the switch and a hot wire from the switch to the lights...and both lights should be grounded
  5. Oct 17, 2008 at 9:25 PM
    JimBeam
    JB
    2015 Tundra
    ive got 2 sets of aux lights wired up essentially the way i just described...no relays...the only difference is i tapped power from my fuse block with an add-a-fuse thingy for each one...i dunno if theres any open fuse slots on yours but thats how i did mine
  6. Oct 17, 2008 at 9:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    why do HAVE to run the wires like that?? wire them like i said,without the relay, and they will work fine. you need to use a 15 amp fuse inline at the battery on the hot wire.
  7. Oct 17, 2008 at 9:27 PM
    JimBeam
    JB
    2015 Tundra
    i agree...delete the relay and run a basic wire setup like we just described and make sure you have good grounds...a bad ground could cause it to not work
  8. Oct 17, 2008 at 9:27 PM
    LonghornTaco
    Minnesota
    I wired it like that because they came with the relays. The line from the battery has a 15A fuse inline...
    I'll see if I can wire it up like yours.
  9. Oct 17, 2008 at 9:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep........i dont ever deal with relays, and i have never had a problem.
  10. Oct 17, 2008 at 9:28 PM
    JimBeam
    JB
    2015 Tundra
    screw the relay...keep the fuse and you should be fine
  11. Oct 17, 2008 at 9:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its alot easier to skip the relay and do it as i described...thats for sure.:D
  12. Oct 17, 2008 at 9:28 PM
    LonghornTaco
    Minnesota
    k - let me try it out. I had trouble with this LAST time I wired the lights on my Chevy...
  13. Oct 17, 2008 at 9:29 PM
    JimBeam
    JB
    2015 Tundra
    ive never used a relay on any of my lights...in fact im still using the original wiring i put in when i put my first set of lights on the truck 3 years ago sans relay and have never had a problem...im on my 3rd set of lights (personal choice not because they went bad) plus ive run a set of aux reverse lights like that and my floorboard lights are run like that
  14. Oct 17, 2008 at 9:30 PM
    LonghornTaco
    Minnesota
    Ok, so my switch has three prongs on the back. Does it matter which prong gets which wire?? I assume it does...
  15. Oct 17, 2008 at 9:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah...you'll get it this time. just take your time. be sure to ground the lights to the battery though.....dont go the easier route and ground them to the frame or a bolt or something.......that aint too great of an idea.
  16. Oct 17, 2008 at 9:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    one will just make the switch light up man..............load goes to positive on battery....earth goes to ground....you can use a frame bolt or something close to keep from running a long extra wire, and the accessory one goes to the hot on the lights!
  17. Oct 17, 2008 at 9:32 PM
    JimBeam
    JB
    2015 Tundra
    does the packaging or instructions have a diagram of which contact is which?
    i have a hot from source, ground, and hot to lights
  18. Oct 17, 2008 at 9:33 PM
    LonghornTaco
    Minnesota
    Yeah, there is a diagram. And ironically enough, there are two "wiring" diagrams on the same page and both say different things about which wire goes to which post.
  19. Oct 17, 2008 at 9:34 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    This is the most basic way to wire lights without using a relay. The drawing is a bit crude. I just whipped it up with paintbrush. :)
  20. Oct 17, 2008 at 9:35 PM
    JimBeam
    JB
    2015 Tundra
    just use the trial and error method...
