Inductive Charger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BarberRider, Apr 12, 2017.
  1. Apr 12, 2017 at 3:16 PM
    BarberRider
    BarberRider [OP] Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    The Qi in my truck has always been finicky at best with my S6. But recently it has started flashing both amber and green lights simultaneously. I'm assuming that's an error message. Does anyone know what the problem could be?
    Also, charging via the usb and the cigarette lighter both suck as well. They are both ungodly slow for me. Has anyone found a fast way to charge your phone?
  2. Apr 12, 2017 at 3:33 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    My USB charges my phone pretty quick.
    Never used the Qi.
  3. Apr 12, 2017 at 3:35 PM
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    Amazon -> Anker USB charger -> $$$
    seriously, the Anker USB charger will fast-charge any compatible phone i've tried with it (Nexus 4, Nexus 5X, Nexus 6P, and Google Pixel).
  4. Apr 12, 2017 at 3:37 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    Plugged directly into the USB port next to the 3.5mm input? Mine charges about 4%/hour, and using the cigarette lighter is almost if not as slow. This is with the red wire that came with the truck as well as the micro USB that came with my winch remote.
  5. Apr 12, 2017 at 3:40 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    buy an anker USB charger with the 2.1 watt or was it amp out put. my iPhone 6 charge from zero to full in less then 45mins.
  6. Apr 12, 2017 at 3:42 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    there is a 24 watt anker that's black with red stripe for like $8. Then there's a 39 watt USB 3.0 that has kindof a carbon fibre look and it's $25.
  7. Apr 12, 2017 at 3:43 PM
    BlakeM
    Blake
    Gonzales, LA
    Yep. That's the one. I also use the red charging cable that came with the truck. I have an iPhone 5, so maybe that's why it charges so fast? Not sure if it'll charge the bigger phones as fast.
  8. Apr 12, 2017 at 4:26 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    Do you have a picture of the qi charger in the truck? I don't have a 3rd gen.
    What I do have is 4 qi chargers throughout my house. Usually when they blink like that the phone needs to be re-positioned for better contact.
    Do you have a case on your phone?
  9. Apr 12, 2017 at 5:05 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    No, and both lights were flashing simultaneously.
    It has worked in the past. Even with my case, I just had to find the exact right spot to put it in. These error flashes are a new occurrence.
    Nevertheless, I just ordered an Anker fast car charger so I should be good to go!
  10. Apr 15, 2017 at 10:26 AM
    bobzilla
    bobzilla Active Member
    Bob
    Northern NJ
    I've tried a few different iPhones and can't get them to charge. Amber light stays on forever, phone makes no progress charging. Otter boxes and cases off and on. Didn't seem to make a difference.
    Any suggestions?
    Bob
  11. Apr 15, 2017 at 10:32 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Not sure if you mean using qi charger but if so iPhone doesn't support qi charging.
  12. Apr 15, 2017 at 10:33 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My note 5 is designed for wireless charging and it only charges 1% every 10 minutes. It's borderline worthless.
    HutchJ likes this.
