Inexpensive but reliable 16" wheels with negative offset (-12 or more). Recommendations Appreciated.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cadmus, Mar 6, 2024.
  1. Mar 6, 2024 at 5:29 PM
    Cadmus
    Cadmus [OP] Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    I bought my truck with cooper discoverers on it. 265/75 r 16. On the OEM snowflakes. I was sad they were in such new shape because I wanted to put bigger wheels and tires on her. It took years before those tires started getting bald. YEAR and YEARS. I waited so long.
    But they got too bald when I was too broke. So to avoid new wheels I got 285/75R16 Cooper AT3XLT discoverers just a couple months ago. Shop said they would not rub. But they do. Inside of the tire on the frame.
    SO. I guess I have to buy new wheels anyways with a 0 or even negative offset. I currently have the stock rims of 15mm.
    What is an inexpensive but bomber 16” wheel brand/model? I do not care about aesthetics. Ability to lift off the "spokes" with a hilift is handy. 6 lug. Thanks for your help.
    NOTE EDIT: title of thread was changed from "0 to negative" offset to now read "negative offset (-12 or more)"
  2. Mar 6, 2024 at 5:31 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Use Vision steel wheels from Summit. They're perfect for you.
  3. Mar 6, 2024 at 5:33 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Those actually nice tires! Cooper doesn't get too much love around here but I'm a fan
  4. Mar 6, 2024 at 6:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wheel spacers
    b_r_o likes this.
  5. Mar 6, 2024 at 7:58 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    A 16x8 4" back spacing wheel works for my 285 75 16's. I can't say they never have made contact with the frame, but I can say it's super rare, maybe when aired down, wheeling and at full lock. Even that is minor, non issue. Daily driving, full lock, no rub. I'm running a wheel similar to this
    https://www.4wheelparts.com/p/pro-c...xXhHVXfOtbOUGZYcr8xoCc-cQAvD_BwE&gclsrc=aw.ds
    The steel "D window" style look to be inexpensive.
  6. Mar 6, 2024 at 8:03 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Check out this thread for SCS blemish wheels. Great value and usually can’t even see the blemish-
    https://www.tacomaworld.com/threads/scs-blemished-wheels.264466/
    edit to add, I don’t know if the 1st gen has the same bolt pattern as the 2nd and 3rd gen…
  7. Mar 7, 2024 at 7:36 AM
    Cadmus
    Fort Collins CO USA
    ".....4" back spacing..." on the same tires.
    That is helpful
    • Size: 16 x 8
    • Bolt Pattern: 6 on 5.5
    • Finish: Flat Black
    • Offset: -12
    • Backspace: 4
    • Max Load: 2200 lbs
    • Center Cap PN: PXA8425042
    So... 4" backspace is -12mm offset and you rarely rub when inflated. So go with -15mm offsets, not 0. Y/N?
    This helps remove the risk of guessing how much i need. Thanks. It think the tread on the sidewall of these new coopers is what the local shop was not counting on when they did their calculations. Do you have side wall tread?
    What lift do you have in the front?
    I have a toytech adjustable strut with only about half or 2/3 the lift used. nothing more. So maybe 2" or 3"
  8. Mar 7, 2024 at 7:42 AM
    Cadmus
    Fort Collins CO USA
    It is an option, but the following are concerns
    -1/2" spacer or even 1/4" means you are loosing a good distance of thread on the lug.
    -1/2" or 1/4" spacers are rarely hubcentric compared to the much fatter ones that mount the wheel to the alternating lugs on the spacer, not the hub.
    -I want to keep the surface of the hub as close to the center line of the wheel as possible so putting super fat spacers on is unwise for me.
    If you want to recommend a good hubcentric spacer that is cheaper than new rims I am all ears.
    Thanks for the help.
  9. Mar 7, 2024 at 7:49 AM
    Cadmus
    Fort Collins CO USA
    Thanks. That was my initial plan, I was posting partly to see if folks here had alternatives and how they stacked up.
    I had them bookmarked before posting here. What is the longevity on those?
    I think i put those on my boat trailer and they see no use sadly (big project).
    Will those spokes/webbing/holes deform or chip if using this to lift a tire? https://hi-lift.com/accessories/lift-mate/
  10. Mar 7, 2024 at 7:57 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    https://www.fnwheels.com/ call Dustin and ask him if they have deals going on. Its my opinion but getting lighter than oem wheels that are hub centric like oem wheels but stronger than oem wheels is really the only way for a wheel to be a true upgrade if you aren't they type of person that needs a beadlock type wheel. Dustin is the best dude in the business and he can hook you up with good deals.
  11. Mar 7, 2024 at 8:01 AM
    Cadmus
    Fort Collins CO USA
    I will investigate this. Thanks.
    $175 is not cheap this year (building a home). I should have upgraded rims and wheels when i had the cash flow 3 years ago.
    The webbing/spokes look chunky enough to accept a hilift. so that is good.
    thanks
    treyus30 likes this.
  12. Mar 7, 2024 at 8:28 AM
    Cadmus
    Fort Collins CO USA
    Yes. After having coopers on several vehicles last SUPER LONG compared to what cooper estimated and going a (near) decade without a leak.... i am now a brand loyalist.
  13. Mar 7, 2024 at 8:46 AM
    Gen1andDone
    Really the rub is so rare that it was almost not worth mentioning.99.9% of the time there is no rub. But there is evidence that it has, YMMV. I don't do well with offset numbers, so I don't know what -15 would be in back spacing or how common that is. Most of the wheels you find will be a 4.5, 4, 3.75...back spacing, 4" is about perfect IMO. As far as I can tell, a 0 offset on an 8" wide wheel equals 4.5" backspacing. That is the same as stock, so no, I wouldn't do 0. Another thing to consider, the more negative offset you go, the more likely it rubs elsewhere (pinch weld maybe).
    I am on OME 882's. They have been on the truck for many years so probably sitting at 2.5" of lift. Lift amount isn't going to have too much impact on frame rub though, unless the suspension never moves haha. Tires are Duratracs, before that I had an older version of Goodyear MT/R's in the same size.
    Cadmus[QUOTED][OP] likes this.
  14. Mar 7, 2024 at 2:25 PM
    Nano909
    Xcab 3.4 4wd 5MT
    I've been using them for a lot of hard offroad miles and they haven't let me down. I haven't tried using a high lift on them, but I don't see why they wouldn't handle it.
  15. Mar 9, 2024 at 12:08 PM
    Cadmus
    Fort Collins CO USA
    Yeah. If steel i assume it would not yield
  16. May 13, 2024 at 11:37 AM
    Cadmus
    Fort Collins CO USA
  17. May 20, 2024 at 3:27 PM
    Cadmus
    Fort Collins CO USA
    Vision HD 85 Soft 8 Series Black Wheels with -15 offset sadly are not able to be mounted without a spacer as they hit the brake calipers (front only). I am posting for archival reasons so no one else buys 6 of these and then has to return them. Bummer.
  18. May 20, 2024 at 3:46 PM
    Gen1andDone
    In a 16" diameter? That's kinda crazy.
  19. May 20, 2024 at 4:09 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Yep I did the same thing. But you can go to oreillys and buy a cheap set of washer style spacers, 1/4" and they work fine.
  20. May 21, 2024 at 10:13 AM
    Cadmus
    Fort Collins CO USA
    Now that i think about it.... steelies are often a flat wall where alloy is cast with more space down there. I should have know.
    I will.... begrudgingly.... try hub centric spacers now. those lugs looked so short the 1/4" or 1/2" spacers looked like not enough lug length. Spacers over 1/2" (with its own lugs pressed into the spacer) looked like overkill putting the weight too far out. But i will. too many here say it is the way to go. thanks.
