Infamous 45-55mph vibrate help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoJuan, Sep 19, 2017.
  1. Sep 19, 2017 at 12:39 PM
    TacoJuan
    TacoJuan [OP] Well-Known Member
    Hanover, PA
    2015 Black Tacoma TRD OR
    I've tried searching and got no luck with what im looking for exactly. I have a 2015 dcsb Off road edition, it's got 5100s on all 4 corners, ome 885s up front with the billies set at 0 and 1.5" wheelers aal in the rear... and I've got the damn 45-55 mph slight vibrate. I've tried a couple things already to fix it like double checking all the bolt torque specs, and making sure each tire was properly inflated. I also have an ome carrier bearing drop kit in, I don't have shims yet but my axle looks perfectly straight. Any suggestions? If anyone else has this set up and could chime in, I would appreciate it. I still have a couple more things to try before I'm at a total loss. I was going to remove the cb drop, and see if that helped, as well as rotate my tires and 2* shims would be a last resort. I just didn't think I would need any drops or shims if I kept it under 3" of lift. Thanks for your help in advance. Will post an update if I figure out what it is.
  2. Sep 19, 2017 at 12:47 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    balance, alignment, rotate..... just to be safe and eliminate that as an issue.
  3. Sep 19, 2017 at 12:48 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Could be the drivers side needle bearing in the front diff- it's a known issue, especially when lifted. If you search, you'll find a ton of threads about it. East coast gear supply makes a bushing to replace it that fixes the issue: http://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html. One supposed way to diagnose is by putting it in 4wd and if the vibration goes away then you found the culprit, but I installed the bushing as a preventative when I installed a lift, so I never had to deal with it.
    Mr. Projekt likes this.
  4. Sep 19, 2017 at 12:49 PM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Vibration, like a buzzing in the steering wheel? Or physically shaking things in the interior? Have you tried switching into 4wd around 45mph and see if it stops?
  5. Sep 19, 2017 at 12:51 PM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    I had that same problem for a year and a half, all I did was replaxw my shocks front and rear and it fixed it. Smooth as can be!
  6. Sep 19, 2017 at 1:05 PM
    TacoJuan
    Hanover, PA
    Just got an alignment right after putting in the new coils and aal, it drives straight as can be. I'm gonna try rotating then re balance if that doesn't work. Thanks
    Mr. Projekt[QUOTED] likes this.
  7. Sep 19, 2017 at 1:08 PM
    TacoJuan
    Hanover, PA
    Thank you! I'll give it a try in 4wd... so if it doesn't go away in 4wd, does that rule out th needle bearing?
  8. Sep 19, 2017 at 1:08 PM
    mtbjohn42
    mtbjohn42 Well-Known Member
    Laporte, CO
    2005 Toyota Sequoia
    Yes
  9. Sep 19, 2017 at 1:12 PM
    TacoJuan
    Hanover, PA
    I guess it would be more like physically shaking. It's not terrible, but it's definitely there. Like I can see it shaking my passenger seat and the antenna and my arm when it's resting on the arm rest. Haven't tried 4wd yet. I'll do that next. Thanks
  10. Sep 19, 2017 at 1:14 PM
    TacoJuan
    Hanover, PA
    I'm hoping it's not this lol. My truck only has 26k on it and 10-12 maybe on the bilsteins
  11. Sep 19, 2017 at 1:14 PM
    mtbjohn42
    Laporte, CO
    2005 Toyota Sequoia
    The needle bearing issue shouldnt produce physical shaking, just an audible sound, much like driving on intermittent rumble strips. At least for me it wasnt physical shaking...
    gunn_runner likes this.
  12. Sep 19, 2017 at 1:14 PM
    TacoJuan
    Hanover, PA
    Ok, I'll give that a try next, thanks
  13. Sep 19, 2017 at 1:15 PM
    TacoJuan
    Hanover, PA
    I can hear it when it's shaking as well as feel it. I'll have to try 4wd. Thanks
  14. Sep 19, 2017 at 1:17 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Have you ruled out the wheels/ tires? I had a bad set of bfg tires that were physically out of round. I warrantied them and problem fixed.
    Might want to try on a set of different wheels/tires if you have that luxury. Maybe a buddy with a Tacoma can help?
  15. Sep 19, 2017 at 1:41 PM
    TacoJuan
    Hanover, PA
    I have thought of that, the vibrations just started shortly after I lifted it half an inch more, and replaced the blocks in the rear with an aal and put the 5100s back to 0 on the front and added ome coils. But, yea I haven't ruled it out yet... could the tires become out of round over time? They're less than a year old but the truck isn't my daily driver so it does sit a bit.
  16. Sep 19, 2017 at 3:56 PM
    TacoJuan
    Hanover, PA
    Just tried putting it into 4wd with no change. The vibration is still there. I'm starting to think one of the wheels is out of round or something
  17. Sep 19, 2017 at 4:07 PM
    NC Taco Camper
    NC Taco Camper Active Member
    Drew
    Charlotte, NC
    2003 White SR5 3.4L 4x4
    Definitely could be tires. Happened on my wife's car and on my work truck. Once I got up to higher speeds had the bad vibrations like you're talking about.
  18. Sep 19, 2017 at 4:51 PM
    gmc8
    gmc8 Well-Known Member
    Gary
    Smoky Mountains
    Subscribed. Mine is stock and does the same thing. Dealer was going to perform the TSB, but turned around and told me it didn't apply to 15s. I was then told it was normal.
  19. Sep 19, 2017 at 5:54 PM
    TacoJuan
    Hanover, PA
    Wow. I haven't heard that before
  20. Sep 19, 2017 at 6:26 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    My thoughts.
    1. Check tire pressure
    2. Rotate tires
    3. Re-balance tires
    4. Bad/damaged tire - bubble/broken cord
    5. Worn out upper strut mount/bushing
    6. ECGS bushing
    7. Bad balljoints
    8. Bad tie rod ends
    9. Bad wheel bearings.
    I had a similar issue. It was a combination of things on my truck.
    ECGS bushing, un-balanced/worn/cupped tires, and bad wheel bearing.s
    smw62891 and TacoJuan[OP] like this.
