Infamous CV growling/noise after 1.75 Bilstein install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Npilcher, Dec 15, 2015.
  1. Dec 15, 2015 at 8:02 AM
    Npilcher
    Npilcher [OP] New Member
    Nathan
    Kernersville, NC
    2010 TRD Sport
    Bilsteins front @ 1.75 1.25 Spidertrax wheel spacers
    I know about the ECGS bushing... Curious how many of you guys with the same issue have "just driven it" for many miles like this, and what the axle looked like once you decided to do the bushing swap.. Was it scared bad? A local 4x4 shop said they never saw the needle bearing fail.. But that's all relative to how many "you've seen"
  2. Dec 15, 2015 at 8:04 AM
    Pigpen
    Dan
    Northwest Montana
    I had over 10k miles on mine after lifting/ before swapping in the bushing. The axle and bearing looked new to the naked eye.
  3. Dec 15, 2015 at 8:08 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Agreed I had about 17,000 miles on mine after putting it at 1.75. All looked brand new as well
