Infamous front click fixed with new mounting hardware? What's the bolt size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Aug 26, 2025.
  1. Aug 26, 2025 at 8:50 AM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    I remember reading on here years ago that the infamous Tacoma front "click" noise you hear over speed bumps can be fixed by getting new bolts for the lower attachment point of the front shocks/struts. I was only able to find this post when I did a search: https://www.tacomaworld.com/threads...ng-shocks-help-resolved.730249/#post-26956757
    Is this a thing? I'm going to replace my front and rear shocks with Bilstein 4600's (I have an SR5 2WD) as a maintenance item and figured I try to get the new mounting bolts in as well if possible. Any suggestions?
  2. Aug 26, 2025 at 10:43 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Just go to toyota and order a 5th gen 4runner bolt for each side. Your stock nut and washer will fit just fine for it.
  3. Aug 26, 2025 at 10:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Bolt is M14. 9/16" (14.3mm) SAE bolt may fit. If you do any dirt/gravel roads, install a nylon locknut. The OEM non-locking nut backed out four times on my truck.
    MR E30 likes this.
  4. Aug 26, 2025 at 10:52 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I did the bolt swap using 4Runner bolts and it did absolutely nothing to stop any clicking. I believe the clicking is at the spring perch and is from the perch slightly moving on the shock body.
  5. Aug 26, 2025 at 10:55 AM
    CenterKnurl
    Is the spring perch the strut mount?
  6. Aug 26, 2025 at 11:03 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I bought the bolts from 303, it was $25 and stopped the front end noise I was having.
  7. Aug 26, 2025 at 11:04 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    With what shocks?
  8. Aug 26, 2025 at 11:05 AM
    Mach
    I know this was an issue with king shocks because of the way they do their bushings but is it an issue with bilstein, etc?
  9. Aug 26, 2025 at 11:06 AM
    Mach
    Were they torqued to spec?
  10. Aug 26, 2025 at 11:10 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Yep. Four times were twice at the lower shock bolt, once at the UCA bolt, and once at the front leaf hanger bolt, all with the same size nuts. They're rotating joints subject to increased vibration off road.
    I carry a few M14 nyloc nuts as trail spare in case the OEM nut comes loose at other locations - very common size in 2nd/3rd gen suspension.
    (I've even had the sun visor screws loosen with vibration.)
  11. Aug 26, 2025 at 11:17 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    That's a lot of bolts to just leave laying around the mall parking lot!!
    I've had both my lowers come loose once, left UCA come loose once and one shackle hanger come loose once. All replaced with nylock nuts. You win on the sun visor though!
    3JOH22A[QUOTED] likes this.
  12. Aug 26, 2025 at 11:19 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Give yer nuts an extra dugga. They'll stay on.
  13. Aug 26, 2025 at 11:26 AM
    ssd2k2
    Keith
    Minnesota
    I would get a click when backing up with my Dobinsons shocks and when I installed my new Bilstein 6112 I changed out the bolts.
    No noise so I assume it was the bolts since everything else was fully torqued. It was cheap and easy so why not
  14. Aug 26, 2025 at 11:51 AM
    CenterKnurl
    Do you remember what the size and length were,?
  15. Aug 26, 2025 at 11:58 AM
    BLtheP
    Plano, TX
    Sorry I should have said spring seat. The circle that sits on the shock c-clip which is what the spring sits on.
  16. Aug 26, 2025 at 12:02 PM
    ssd2k2
    Keith
    Minnesota
    xp0nex and bkhlrTaco's like this.
  17. Aug 27, 2025 at 2:56 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    5100 for both Tacomas for 7 years and no issues!
  18. Sep 5, 2025 at 8:55 PM
    CenterKnurl
    ssd2k2[QUOTED] likes this.
  19. Sep 5, 2025 at 9:05 PM
    BLtheP
    Plano, TX
    In my experience the bolts did absolutely nothing. And in theory, they shouldn’t do anything because the bolt is supposed to be clamping the sleeve so tightly that things can’t move at all down there.
    Like I’ve said before, I believe it’s the lower spring perch/seat shifting on the shock body. You probably have a nice fresh connection there on your new 4600s. The factory shocks have a glue holding the perch still and that glue is known to come off. Then the shifting and resultant clicking starts.
  20. Sep 5, 2025 at 9:09 PM
    CenterKnurl
    Do you mean the ring towards the bottom of the strut body that the spring sits on? Even with the Bilsteins, the ring just sits there it's not even glued or anything.
