Inferno Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by frymy14, Sep 15, 2015.
  1. Feb 16, 2018 at 6:38 PM
    #4361
    wahudiditagain
    wahudiditagain Well-Known Member
    Wes
    Central Ohio
    2017 TRD OR DC 4x4 Inferno
    No, but I'm sure he could do it. Ohio not known for its fantastic topography to wheel on. Unless farmer's fields count?
    smugly and RobP62[QUOTED] like this.
  2. Feb 16, 2018 at 7:05 PM
    #4362
    Garwood
    Garwood Well-Known Member
    Pensacola, FL
    2002 TRDOR Xtra Cab 5spd MT
    Man... I've been staring at this pic for way too long.
  3. Feb 16, 2018 at 8:26 PM
    #4363
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
  4. Feb 17, 2018 at 1:11 AM
    #4364
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Howdy! fellow Ohioan!
  5. Feb 17, 2018 at 3:33 AM
    #4365
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    For those of you who hand wash your trucks, what's the best thing to dry it with? I have a brand new microfiber drying towel that says it can dry an entire vehicle I think without being wrung out or somethin.
    Anyways, just want to be sure it won't leave any swirl marks or scratches on the surface of this gorgeous Inferno paint
  6. Feb 17, 2018 at 5:18 AM
    #4366
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    I use a Chemical Guys drying towel and it works great!
    https://www.amazon.com/dp/B001TZBQ0...b7a3-da7c528408ba&ie=UTF8&qid=1518873738&sr=2
    But before I dry with the towel I "pool" the water and use a leaf blower to blow off as much as I can, then dry with the towel.
    CodyH.[QUOTED] and Keith_Stone like this.
  7. Feb 17, 2018 at 7:03 AM
    #4367
    Csbryan1
    Csbryan1 Well-Known Member
    Carter
    Memphis, TN
    2016 Inferno OR DCSB
    I use an EGO battery leaf blower. Works perfect and doesn’t leave swirl marks or water spots. It’s the best thing I have found.
    CodyH.[QUOTED], RobP62 and rlx02 like this.
  8. Feb 17, 2018 at 8:01 AM
    #4368
    EL Taco Verde
    EL Taco Verde Well-Known Member
    2021 TRD Off Road
    Factory lift kit. Lomax tri fold Tonneau.
    I use a "California Water Blade" on glass, then towel the body. I have used blade for many years including on collector vehicles, The only negative with high pressure blowing is that it forces water in areas that usually you do not want excessive moisture to get into such as between body panels or exacerbates a problem such as third brake light gasket problem.
    CodyH.[QUOTED] likes this.
  9. Feb 17, 2018 at 8:19 AM
    #4369
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Yeah, the harbor freight one will work just fine. Whatever you do, don't get a drill attached one or a cheap 10 dollar wax spreader from an auto parts store.
    You'll need to buy at least a white, orange or yellow pad as well. The link in my sig has instructions on how to get rid of trail pinstriping which is the same as fixing the marring on your paint.
    But your clearcoat is fine and all there, just a little marred up probably from you using a microfiber towel on it too aggressively.
    RobP62[QUOTED] likes this.
  10. Feb 17, 2018 at 8:29 AM
    #4370
    wahudiditagain
    Wes
    Central Ohio
    Leaf blower for the win! I've been using one for a couple of years. Works great and no rubbing your wax off by drying with a towel or chamois.
  11. Feb 17, 2018 at 8:47 AM
    #4371
    SuperTrooper864
    SuperTrooper864 Well-Known Member
    Upstate South Carolina
    17 SW 4x4 DSCB
    'Preciate it brother.
  12. Feb 17, 2018 at 9:32 AM
    #4372
    Csbryan1
    Carter
    Memphis, TN
    That’s why I like the EGo blower. It’s had a variable CFM. So you can control the power of the dry.
    EL Taco Verde[QUOTED] likes this.
  13. Feb 17, 2018 at 10:46 AM
    #4373
    christopherlowe1234
    christopherlowe1234 @bluecollaredtaco
    19 OR/MT
    See build thread
    I made the bed bars, they are mounted into the factory rails.
    Bike racks are Yakima high roller, and the middle basket is a Yakima load warrior.
  14. Feb 17, 2018 at 11:01 AM
    #4374
    christopherlowe1234
    19 OR/MT
    See build thread
  15. Feb 17, 2018 at 12:54 PM
    #4375
    CodyH.
    Cody
    Arizona
    Damn I had no idea using a leaf blower to dry a vehicle was so popular. I'v actually never heard of that method until now. I do have a shop vac with a blower attachment but the speed is not adjustable. I guess I'll have to maybe give it a try. But I still wanna try using the towel I have, just concerned whether or not it will cause swirls on the surface even tho it is microfiber
  16. Feb 17, 2018 at 1:45 PM
    #4376
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    @rlx02 @the_dau @smugly @pdenajim @Malibu7tss
    Ok, who had cleaner wax? Winner winner chicken dinner!
    No more spots! As a matter of fact here is the one with that spot.
    You can still that spot, so it must be a small chip or a flaw in the paint but the dull mark that was there is gone!
    :taco::taco::taco::taco::taco::taco::taco::taco:
    :yes::yes::yes::yes::yes:
    So thank you all again! You guys really helped an old OCD guy out!
  17. Feb 17, 2018 at 3:05 PM
    #4377
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    That stuff does work wonders.
    RobP62 likes this.
  18. Feb 17, 2018 at 3:24 PM
    #4378
    K-Bear
    K-Bear Well-Known Member
    Been wanting to do this for awhile but just got the free time today. 10x happier with the front of my truck now!! :amen:
    4A30A4E4-3623-4B04-B78E-2508BCF8F28F.jpg AA735B98-6BD3-4048-B2B9-E108F2A7111C.jpg
    SilverII, qcarr, Keith_Stone and 8 others like this.
  19. Feb 17, 2018 at 4:03 PM
    #4379
    nouel87
    nouel87 Well-Known Member
    Jerimiah J.
    The Grey Lady
    2017 Tacoma TRD OR DCSB Inferno
  20. Feb 17, 2018 at 4:06 PM
    #4380
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Nice....:thumbsup::thumbsup:
    K-Bear[QUOTED] likes this.
