Inferno Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by frymy14, Sep 15, 2015.
  1. Apr 13, 2018 at 8:30 PM
    #5221
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    My Tundra and 4Runner were both MGM. Had to have the Inferno Taco though. I've seen a Inferno Tundra and the body is too smooth to pull it off. I've seen a pic of a Inferno 4R. That works.
    cratagus likes this.
  2. Apr 13, 2018 at 9:29 PM
    #5222
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    I highly suggest doing it right and painting them. I did mine with a satin finish. Turned out great. I painted so that i would have no issue when pressure washing.
    RobP62 and smugly[QUOTED] like this.
  3. Apr 14, 2018 at 7:42 PM
    #5223
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Embraced my Inferno side a lot more today.........
    Went to the grand opening of 4Wheel Parts today and hung out with some of the Md members of TW. Great peeps, had a great time! Came home and knocked out some simple mods since it was over 70 degrees.
    First up I finally fixed that damn passenger side mat that was shifting all the time.
    That was easy enough and cost like 5 bucks.
    Then, I proceeded to derp my door badges and remove the hideous silver pin stripes (silver, really, on inferno!?). So after I started the derping process I would work on a section of pin strip to allow for some drying time. Worked perfectly since the stripes were coming off a half an inch at time :frusty:
    It was windy as hell so this didn't help at all. Luckily I bought the 3M Adhesive Remover just for this project. I had overspray on the back doors :facepalm:
    All said and done it worked out and only took like 5 hours for everything o_O
    I like the badges so much I am going to follow some others lead and remove and paint them properly so I don't have to worry about it coming off.
    I still have to say though, the best part of the day was driving my Tacoma to a event and hanging out with other TW members. :thumbsup:
    This forum is fantastic!
  4. Apr 14, 2018 at 7:52 PM
    #5224
    Solmimi
    Solmimi Well-Known Member
    SolSand
    League City, Tx
    2016 Tacoma TSS Double Cab
    6.5" Maxtrac w/ 5100 Billsteins all around
    On plasti dipping the badges, I've seen hundreds of posts and twice as many videos but I still don't understand? What keeps the Plasti Dip from sticking to our beautiful paint jobs?
    RobP62[QUOTED] likes this.
  5. Apr 14, 2018 at 8:12 PM
    #5225
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    It's really not paint. It's a rubberized, colored coating. Key word being "coating" which means it's not permanently bonded to the surface its sprayed on. It can peel off. Now, when I did my grill I also shot it with a Plastidip brand Glossifyer. This is a clear component and makes the rubberized coating harder and more stabilized, ie, less likely to peel. I have it but didn't have the time to do the door badges with it.
    Even after watching those said hundreds of videos and reading those hundreds of posts, when I peeled away the excess even I was amazed how it broke/tore where the letters meet the door skin. If you look closely they don't actually touch, and there is a little gap. That's all it needs apparently to come away clean.
    Like I said though, this can peel off so I will be painting properly. But for now, with less effort, this is perfect.
    pdenajim likes this.
  6. Apr 14, 2018 at 8:38 PM
    #5226
    orion808
    Florida
    Exactly. It will peel if coerced near any edge of if you nick or cut it.
    Overspray is the main issue. Due to the properties, a little overspray is worse than intentional overspray. You don't want the wind catching it and have to pick a bunch of little dots off the side panels, but peeling it up as a sheet is nice and clean.
    YouTube "dip whole car" and you can see how tough, thick, etc the stuff is.
    RobP62 likes this.
  7. Apr 14, 2018 at 8:52 PM
    #5227
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Exactly, and the only con is the wait between coats. On warm day though not a big deal.
    I had a lot of overspray, and it was minimal, which as you say is bad. I just sprayed the hell outta the areas with that 3M Adhesive remover and it wiped right off. Knowing what I know now I would not do it on such a windy day, and I would use more paper to cover more of the truck.
  8. Apr 15, 2018 at 4:30 AM
    #5228
    Solmimi
    SolSand
    League City, Tx
    Excellent explanations and much appreciated.
    RobP62 likes this.
  9. Apr 15, 2018 at 4:37 AM
    #5229
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    So how do the badgers come off and go back on?
  10. Apr 15, 2018 at 4:41 AM
    #5230
    smugly
    Doug
    I will add one more thing to all the great info they have given. The more coats you put on the easier it is to peel
    RobP62 likes this.
  11. Apr 15, 2018 at 5:33 AM
    #5231
    orion808
    Florida
    I had removed mine with fishing line wrapped around my fingers (gloves suggested). Best on a hot day. The adhesive foam is sticky, but it isn't too much of an issue with Goo Gone. I taped around the badges with painter's tape to give a reference for when I was ready to reapply the badges.
    1/4" 3M foam adhesive is placed on the back of the badges. Honestly, this is the hardest part. By hard, I mean tedious. I sat and watched a couple TV shows while I cut each piece.
    Result is awesome though.
    SilverII, ToyoDrew, AZJuice and 2 others like this.
  12. Apr 15, 2018 at 6:25 AM
    #5232
    toddulu
    toddulu Active Member
    Todd
    Fresno, CA
    2019 Cavalry Blue TRD OR DCSB
    RobP62 likes this.
  13. Apr 15, 2018 at 7:59 AM
    #5233
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Ha!!! Finally did it !! Ordered these .
    BEDE6B14-584D-4F01-992A-557938D289A3.jpgGot the orange beads and a set of black beads !! Happy Halloween!
    Naflash and RobP62 like this.
  14. Apr 15, 2018 at 8:14 AM
    #5234
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Wow! Can't wait to see them on.
  15. Apr 15, 2018 at 9:28 AM
    #5235
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Both of these are great posts about this. Thank you for them. :thumbsup:
    There is definitely a feeling of extreme gratification doing a mod like this because it's not too difficult yet the result, as we've all said, is very dramatic.
    With all that said, I'm wondering if there is a quicker method. Basically, our time is so limited and since this type of mod is weather dependent, would it just be more efficient to either buy a second set of badges and do all the paint work in stages, then in under an hour, swap them out.
    Or, and I know this is really not in the spirit of a true conversion, just buy black badges and swap them.
    I just have to wonder how much our time is worth in the long run?
    I also have to wonder what all the guys taking them off their truck on the forum are doing with them and how much they'd be willing to sell them for. I'd buy a use set if the price was right. Hell some guys might even give them away and just charge for shipping :boink:
    smugly and CPTtacoWV3 like this.
  16. Apr 15, 2018 at 10:24 AM
    #5236
    SCboater
    SCboater Well-Known Member
    Jeff
    2017 TRD off road inferno red
    Best looking chrome wheel I've seen in a while. Should look good on the truck.
  17. Apr 15, 2018 at 1:22 PM
    #5237
    rongoms
    rongoms Active Member
    Ron
    Forest Compound outside of Seattle
    2018 TRD Off Road Inferno Double Cab, 2010 FJ Cruiser, 1992 Land Rover Snatch
    AZJuice, RobP62 and over60 like this.
  18. Apr 15, 2018 at 4:39 PM
    #5238
    EL Taco Verde
    EL Taco Verde Well-Known Member
    2021 TRD Off Road
    Factory lift kit. Lomax tri fold Tonneau.
    those got my attention, you have to post when mounted. :thumbsup:
  19. Apr 15, 2018 at 5:30 PM
    #5239
    Tacomamike mike
    Michael
    Maybe :) because I’m not really excited about them :)
  20. Apr 16, 2018 at 5:12 AM
    #5240
    CPTtacoWV3
    CPTtacoWV3 Well-Known Member
    Mitch
    West By God Virginia
    2017 Inferno Tacoma TRD Sport M/T
    I can't remember where I saw it, but the idea I think I'm gonna go with is similar to the black lettering on the tailgate. Just black decals that go over the badges. It's a neat look, where you can still see a little of the chrome, but black is the forefront. I'm probably going that route eventually.
    RobP62[QUOTED] and Naflash like this.
