infinity reference 5350a Amp and 5 channel patch cable included!
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by BRYLONATOR, Apr 16, 2012.
  1. Apr 16, 2012 at 7:01 PM
    BRYLONATOR
    BRYLONATOR [OP] Building 06 Suburban K2500 with LBZ D-max and ZF6!
    Denver, Colorado
    Chillin in a 120!
    This amp saw very little use and is in guaranteed condition to be like new!
    specs:
    5-channel car amplifier
    50 watts RMS x 4 + 150 watts RMS x 1 at 4 ohms (60 watts RMS x 4 + 300 watts RMS x 1 at 2 ohms)
    120 watts RMS x 2 at 4-ohms + 150 watts RMS x 1 at 4 ohms in 3-channel mode
    CEA-2006 compliant
    variable high- and low-pass filters (32-320 Hz, 12 dB/octave)
    variable bass boost (0-6 dB at 50 Hz)
    Class AB 4-channel amp with Class D mono sub channel
    MOSFET power supply
    3 sets of preamp-level inputs
    fuse rating: 40A x 2
    17-1/16"W x 2-11/16"H x 9"D
    Street wire patch cable which is expensive!! $120 new and allows one set of wires to be run for fronts, rears, and sub! (It's the special RCA cable that handles all channels)
    $200 + shipping
