Info about air conditioner odor
Discussion in 'General Automotive' started by genxer36, Apr 8, 2009.
  1. Apr 8, 2009 at 11:43 PM
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    What causes air conditioner odor? How can I prevent the odor from occurring?
    From the Toyota website.
    During air conditioner operation, cold refrigerant is pumped through the evaporator core by an engine-driven compressor. A fan then blows air through "fins" in the evaporator to cool the air. These fins also act as an air filter, trapping bacteria, spores, and dirt. These airborne particles are normally washed out a drain hole with condensation, but if they remain on a moist evaporator, they may collect and cause an unpleasant odor. This effect is more frequently found in humid climates where more condensate accumulates. This situation is not unique to Toyota; it is an industry-wide condition.
    To prevent the odor, Toyota recommends the following:
    • Avoid parking under trees to reduce the possibility of leaves entering the air intake
    • Use the fresh air setting on your climate control rather than the recirculated air setting whenever possible to allow the evaporator to dry out
    • Drive on paved roads whenever feasible as dusty conditions may accelerate the condition
    If the condition already exists, spraying a mixture of isopropyl alcohol and water (1 to 5 ratio/mixture) or a disinfectant in the outside air intake may help reduce the smell. If these steps do not alleviate the odor, we encourage you to contact your local dealer for a thorough evaluation of the condition.
  2. Jul 3, 2009 at 10:44 AM
    aacomi
    aacomi Member
    Red Bay, Alabama
    2005 SR5 tacoma 4x4
    this happens also with residential heat pump/ac units in the mid to south east states.......we call it the dirty sock syndrome.....it is cause by bacteria getting on the evaporator coil.......it should cure itself eventually when the condensate actually washes the coil several times........
  3. Aug 9, 2009 at 6:30 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    while driving with the a/c on, a few minutes before arriving at your destination turn the ac off and just run the fan on a high setting. this will help to blow/dry up accumulated condensation out of the air paths so that build up will not occur
  4. Sep 29, 2009 at 6:31 PM
    dsds
    dsds Well-Known Member
    Calgary AB
    2008 DC TRD Sport - Black Sand Pearl
    TacomaWorld sticker, DRL mod, running boards, roof rack, remote start / security alarm, marker/turn signal mod, map light with dome light mod, TRD seat covers, rear spring TSB
    I've read that checking the "drain tube on the AC box" is the thing to do to make sure water is ok to drain.
    Where is the drain tube and where is the AC box?
    Maybe dumb question but I'm too dumb to care about snide remarks.
    Thanks! Gotta get rid of the smell before a hot date!
    Cheers!
  5. Mar 28, 2010 at 12:32 PM
    JKD
    JKD Well-Known Member
    I saw this while searching for something else, and I thought I'd add this. The Dodge/Plymouth Neon owner's website has a TSB on this, with a good procedure for eliminating A/C odor:
    http://www.neons.org/neontsb/TSB/24/241197.htm
    I know some people have used Lysol disinfectant spray instead of the specified "evaporator coil cleaner" and have had good results.
  6. May 27, 2010 at 10:22 AM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Agree with old soul here... run the fan with A/C off before shutting your truck off.
  7. Jun 16, 2010 at 6:13 AM
    Barnone
    Barnone Guest
    I did the run A/C blower on high in out side air mode and spray shower cleaner (bleach) in the cowl intake to get rid of the smell. It did take two treatments to get the job done.
  8. Jun 16, 2010 at 6:18 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You wouldn't have this problem if you regularly replaced your cabin air filter. It protects your evaporator from exactly what they're talking about, JUST like the filter in your unit at home. Check and change them as often as necessary.
  9. Jun 16, 2010 at 6:20 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    If you open your hood, on the passenger side on the firewall will be a small rubber tube angled downward at about 45 degrees. That is your condensate drain.
    The A/C box is located behind your glove compartment.
  10. Feb 28, 2011 at 12:42 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Good I didn't have to post it.
    If its a hot rainy day (can't crack windows) I'll even turn the heat on when I enter the sub division. Help dry out that coil.
  11. Mar 4, 2011 at 11:16 AM
    sxgt
    sxgt Member
    03 DC SR5 4WD TACO
    Correct me if I am wrong - 1st GENs do not have in cabin filters. Good tip for 2nd GENs though.
  12. Mar 4, 2011 at 11:35 AM
    genxer36
    Sean
    Bethlehem,GA
    Some 2nd gens do not have cabin filters. I know the 2005 doesn't
  13. Mar 4, 2011 at 11:42 AM
    genxer36
    Sean
    Bethlehem,GA
    True for those that have cabin filters. Alot of the trucks do not have them. I'm not sure what year Toyota started putting the cabin filters in the Tacoma's. Anyone know? Was it 2007 forward?
  14. May 25, 2011 at 12:37 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My 2006 has a cabin air filter.
  15. Aug 20, 2011 at 11:35 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Did your truck come with one in it? Or just option to install.
    I know alot of trucks that came with the space for one..but never had one.
    Fuck paying $30 for a filter.
    Another reason why I don't like 2nd Gens.
  16. Aug 21, 2011 at 1:30 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yup. Works every time for me.
  17. Jun 10, 2012 at 6:27 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    At some dealerships they use a foam that is sprayed in through the drain hole, it cleans the evaporator core. Corrosion and dirt can affect the ac's function and cause funk.
  18. Jun 10, 2012 at 6:46 PM
    genxer36
    Sean
    Bethlehem,GA
    You can spray Lysol into the vent intake just below the windshield (on the outside of the windshield) with the A/C running, put the fan on full , & the windows down. The Lysol will kill the bacteria & mold in the system.
    shakerhood likes this.
  19. Sep 1, 2014 at 9:26 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    If you're under warranty, they should take care of the odor at no charge. This issue goes back to at least 2006. I purchased a 2007 is250 in august 2006, ran the a/c all the time and ran across the TSB for A/C odor. I don't remember if it smelled that bad or I just took it in to be a dick and put miles on the free loner vehicle.
  20. Jul 18, 2015 at 1:20 PM
    Mfreund1
    Mfreund1 Well-Known Member
    Eastern Ia
    2007 SR5 Sport
    This happened on my wife's 2009 Traverse. The book says there is a cabin filter but there is not. My 2002 Silverado has a cabin filter and replaced it with one with Febreeze in it and smells but does not stunk.
