Info about Light Racing UCA's.
Discussion in 'Suspension' started by Fabulous, Nov 16, 2010.
  1. Nov 16, 2010 at 1:07 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    So with all the pain in the ass I'm having getting my truck aligned even half decent after my lift, I'm considering some UCA's...the Light Racing ones. I don't off road, so these should be good, correct? When I get them I just need to set them at the 0 setting to increase my caster right? How about the camber? (the area of concern for me right now). Some insight on what to do with these would be appreciated, as I did some searching, and couldn't dig up a lot.
    Thanks.
  2. Nov 16, 2010 at 1:39 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    they come with a paper to tell you(or the alingment shop)which position is what degree.
  3. Nov 16, 2010 at 1:45 PM
    Fabulous
    Fabian
    Calgary, AB
    I'll be installing them myself, and heard that I need to put them on the 0 setting...does that take care of the camber, and caster?
  4. Nov 16, 2010 at 1:47 PM
    DevL
    DevL Well-Known Member
    I have seen no evidence that LR has less travel than TC UCAs. Light Racing ball joint have much more travel than the factory ball joints.
  5. Nov 16, 2010 at 1:50 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I've been running them for over a year with no issues at all. Increased travel, better alignment, no maintenance, and one of the cheaper UCAs out there. :cool:
  6. Nov 16, 2010 at 1:52 PM
    Fabulous
    Fabian
    Calgary, AB
    How are your set? Are they at 0 with the writing on the brass piece facing out? Easy to install? I installed my lift myself, so I figure I can handle the UCA's as well...
  7. Nov 16, 2010 at 1:55 PM
    RelentlessFab
    Eric
    I set mine with the Ball joint rotated back one notch to help clear my coil springs at full droop. The alignment shop had no problem getting it in spec like that. :cool:
  8. Nov 16, 2010 at 1:57 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    the adjustments are for when they put it on the lift and do the alignment. Thats all. The 0 is just a neutral setting so when they do start your alignment they dont have to put it back to 0 and start from there, its already at 0.
  9. Nov 16, 2010 at 2:51 PM
    Fabulous
    Fabian
    Calgary, AB
    But at the 0 is it already providing more caster adjustment right off the bat? Like with a 2.6" lift where is the best place to set it at? I don't want to leave it to the alignment guys...there is nobody around here that will know how to do that kind of stuff, so I'll have to make it easy for them.
  10. Nov 16, 2010 at 3:58 PM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    Unfortunately I think you'll have to leave it to them - nothing in suspension is absolute - there is no setting that you know will be right from the beginning. I would leave it at the neutral-most setting, then they will have to take it from there.
    -Sam
  11. Nov 16, 2010 at 9:01 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Fabian , not sure it helps but I bought the LR UCA's ( not installed yet ), they come with a ' chart ' showing how the positioning of them relates to your alignment .
  12. Nov 16, 2010 at 10:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  13. Nov 16, 2010 at 10:27 PM
    OZ-T
    Peter North
    British Columbia
    :mudding:
  14. Nov 16, 2010 at 10:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    great info! love the chart.
  15. Nov 17, 2010 at 12:04 AM
    RelentlessFab
    Eric
    So based on that chart I'm dialed to +1* caster.
  16. Nov 17, 2010 at 7:37 AM
    Fabulous
    Fabian
    Calgary, AB
    Awesome, thanks guys. I have the truck in for another alignment today just to see if they can get it better... had one on Friday, and they set the camber WAY too high, and at full lock going up a driveway, etc it is rubbing on the back of my lower a-arm, and frame a bit. I think I will def need some UCA's.
  17. Nov 24, 2010 at 3:35 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    Did you get the LR UCA's?
  18. Nov 24, 2010 at 7:27 AM
    Fabulous
    Fabian
    Calgary, AB
    No, not sure I will need them now. Had Toyota redo my alignment, and I'm happy with it for now. They got my caster/ camber to very acceptable numbers. I guess I'll have to see if I really need them in the future, but with Christmas right around the corner, I'd rather have the $400 in my pocket right now.
