Info for rebuilding 3.4 engine and increase HP
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma_1996@47, Sep 26, 2020.
  1. Sep 26, 2020 at 3:59 PM
    tacoma_1996@47
    tacoma_1996@47 [OP] New Member
    D
    Tacoma 96
    Hello to all I'm new to this forum looking for advice or tips on rebuilding 3.4 Tacoma will like to increase horsepower Might as well since Engine will be taken apart
  2. Sep 26, 2020 at 4:03 PM
    Clearwater Bill
    Billy
    Largo Florida
  3. Sep 26, 2020 at 4:07 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    How much are you willing to spend?
    The only real viable power adder is a supercharger or a turbo. There isn't a lot of "internal" stuff you need to do, or even can do. These motors handle the SC's just fine. It's a factory option even...
    Aside from the SC, I wouldn't waste your money on engine components. If that's not enough HP for you, get a different motor.
    b8hickman and Hamer95USA like this.
  4. Sep 26, 2020 at 4:09 PM
    tacoma_1996@47
    D
    Tacoma 96
    Thank you for the information that's what I was afraid of 3g for a SC
  5. Sep 26, 2020 at 5:51 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  6. Sep 26, 2020 at 9:44 PM
    jbrandt
    Justin
    SC's are still the best bang for your buck. And they are essentially "bolt on" (since they were a factory option). Headers/exhaust and that type of stuff really doesn't amount to much, except a change in the noise. I'm not even aware of "performance" cams, or high comp pistons or whatever for our trucks. I'm sure someone makes them, but they're probably just as expensive as a SC, and don't give you nearly the gains. The 3.4's just aren't one of those motors people build for power.
  7. Sep 26, 2020 at 10:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Port and polish the heads and turbo or supercharge but you’ll possibly not make the smog sniffer happy if you need to pass inspection with messing with the heads - not sure it would affect it though.
  8. Sep 27, 2020 at 2:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is sad so many never list where they live and what kind of emissions inspection they go through
    Forced induction the best way .
    Then the down side to increased Horse Power and Torque is breaking things the weakest link always breaks .
    You want horse power Small block Chevy though my days of 500 hp + engines are long ago and I have not really keep up
  9. Sep 27, 2020 at 8:15 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Here a small info bit. Probably irrelevant and somewhere better to post but I live in CO. Last emissions I passed with no issues and my EGR system is eliminated. Here in CO, they don’t do engine bay inspections I’m my experience, but my trucks have never “looked” like there would be engine modifications either.
  10. Sep 27, 2020 at 8:32 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
  11. Sep 27, 2020 at 8:41 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    A natural aspirated engine will only gain significant power with additional displacement. IE a bigger engine.
    Otherwise, forced induction will give gains.
    Always be aware of the mechanical limits of the equipment attached to the engine. IE tranny, Xfer case, Diffs, CV joints, prop shaft & U-joints, motor mounts and frame to name a few.
    My point is....its not just more power from the engine......everything else must handle that power.
    NSDON and crazytacoman like this.
  12. Sep 27, 2020 at 9:49 AM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Right on. One of my all time favorite videos is from Tom's Turbo Garage, in which he swaps in a v8 into a 2002 tacoma and turbo charges it as well. He also makes sure to get a good transmission, suspension, exhaust, and other, so that the truck could handle such power.
    Here's a link to it: https://youtu.be/Ur61jLKcXa0?t=1043
  13. Sep 27, 2020 at 11:05 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You’re not going to overpower drivetrain components with anything you can do to the engine on these if you’re not already aware of what your options are and asking forum guys the question you asked. Gimmicky stuff like the lightweight crank pulley and aftermarket intakes just give you placebo HP until you’re forcing air through the engine and can begin to have more untapped HP. If you’re not turboing or supercharging your best performance “mod” is good maintenance. LCE does sell a heavy weight flywheel which won’t give you added HP or acceleration, but helps keep engine speed up on trails and freeway driving without having to push the accelerator down as much, but if you want more power for accelerating you could install shorter gears.
    Hamer95USA, NSDON and Wyoming09 like this.
  14. Jan 7, 2022 at 5:24 PM
    Eldiablo14
    Eldiablo14 New Member
    Now I know this forum is old. But, you guys have obviously never ported , flowed, matched an engine berfore. I just picked up my first third gen 4 runner with 3400. I ll pull it apart rings bearings, port and match the heads, get some cams, even if I have to have engle make them, do a couple other tricks. Extrude hone the intake add some headers. We will see where were at. A couple little turbos hanging off the stock flowed exhaust manifolds would be cool, can get those off ebay. Just put american bearings in them. How do I know. Done this berfore alot for customers. Not looking to invent the world just be a little cool and spool my ass off. lol.
  15. Jan 7, 2022 at 11:34 PM
    Eldiablo14
    NO kidding I just so happen to have been building race stuff for a long time. YOur just talking easy made hp.
  16. Jan 8, 2022 at 12:19 AM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    go on lcengeneering they have performance parts for the 5vz
  17. Jan 8, 2022 at 3:31 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    For anything you think you can buy to add real hp, ask or search on here to check it out first to see what gains you can expect for torque and hp. Read about gains from say a K&N air filter, then check here and find out there are really no meaningful gains there plus it will foul your sensors from the oil used (btw I have a k&n in my old car, no sensors).
    If there is a solution to meaningful hp gains on the 3.4 other than adding a turbo/SC, backed by a dyno of the before and after performance change, let’s see it?
    Bivouac likes this.
  18. Jan 8, 2022 at 7:37 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    OP isn’t going to read this - hasn’t been on here in 3 years…
  19. Jan 8, 2022 at 7:41 AM
    Glamisman
    Glamisman Well-Known Member
    some motors react better than others to HP mods… it all comes down to how much $$$ you want to spend per HP. This is similar to the mpg crowd, headers, new exhaust, etc cost thousands… to make 1.1 more mile per gallon. I had a buddy tell me that he was going to buy a Prius to save on gas. I asked him how far is your commute to work, he said 7 miles. hmm $25k to save pennies on fuel, doesnt pencil out for me.
    alarka likes this.
