Info for wiring LED harness switch into 2013 cab/dash?
Discussion in 'Lighting' started by 1TacoID, Jan 25, 2022.
  1. Jan 25, 2022 at 8:13 AM
    1TacoID
    1TacoID [OP] Well-Known Member
    Central Idaho
    2013 Tacoma TRD Sport 6 Speed manual.
    Bilsteins 5100, OME 886 coils + leafs, well, not much really...Geolandar X/ATs. ARB "bumper".
    Hello,
    I bought and installed an Extreme LED 22" 200w lightbar on my ARB bumper, but I'm not sure how to get the on/off switch "into" the cab... So it looks nice but not working yet.
    Any suggestions? or direct to any earlier post / reference, etc? Any help appreciated.
  2. Jan 25, 2022 at 8:16 AM
    Tacospike
    Two Trucks
    In the engine bay driver side, there is a grommet to go into the cab, will come through above your break pedal. Will probably want to remove the wires from the switch when you pass it through.
  3. Jan 25, 2022 at 9:07 AM
    1TacoID
    Central Idaho
    Thanks. I'll give it a try!
    Tacospike likes this.
  4. Jan 25, 2022 at 12:37 PM
    1TacoID
    Central Idaho
    OK, done.
    I used a long 1/4"SS rod cut @ 45 deg- with the wire connector taped - to pierce the boot from the inside.
    Light works and so does the switch cut into the lower dash. :)
    thx.
  5. Jan 25, 2022 at 12:43 PM
    Tacospike
    Two Trucks
    :cheers:
