Info needed Hilux springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Griffids, Mar 12, 2019.
  1. Mar 12, 2019 at 3:31 PM
    Griffids
    Griffids [OP] New Member
    2017 Tacoma DBL cab TRD off road
    I am looking for information on the possibility of using Hilux rear springs on my 17 TRD OR. I am currently running OME HD but need a bit more spring rate. Any information on utilizing HIlux leafs on a third gen would be appreciated.
  2. Mar 12, 2019 at 3:34 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Hilux is a different truck
    If you need a higher spring rate use an OME add a leaf or switch to something like Deaver Expos 3. They both are Taco specific and will get the job done better than a product not meant for your truck at all.
    JoeCOVA and Griffids[OP] like this.
  3. Mar 12, 2019 at 3:40 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    They probably won't work unfortunately, and if they did it wouldn't be a huge difference
    Deavers or AAL would definitely work out better as stated above
    Griffids[OP] likes this.
  4. Mar 12, 2019 at 4:18 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The Hilux springs are too short, roughly 24" from the center pin to the center of the forward mounted bushing. Tacomas have about 27.5" for this measurement.
  5. Mar 15, 2019 at 6:55 AM
    Griffids
    Thanks for the information guys..much appreciated!
    upTOPOverland_Drew likes this.
