Info on the Denso Fuel Pump Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skiploder, Sep 17, 2020.
  1. Sep 17, 2020 at 8:23 PM
    skiploder
    skiploder [OP] Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Sincere apologies if this has already been posted.
    A friend of a friend is the service manager at a local Toyota dealership. I ran into him at the grocery store last week and was needling him about the recall..specifically what the mode of failure was.
    To my surprise he called me this afternoon and gave me a fairly detailed rundown of the problem and the mode of failure. From my notes:
    The mode of failure is deformation of the impeller. The deformation can cause a variety of failure modes from hitting the side of the unit to rotating erratically and failing to draw enough fuel into downstream components like the HPFP. Damage to the HPFPs have apparently been seen in some of the LPFP failures.
    The cause of the failure was apparently exposure to a drying solvent for an extended period of time which results in fine cracks that absorb fuel and expand over time. The faulty LPFPs have an impeller made of a low density material that is prone to micro cracking when exposed to the drying agent used in manufacturing.
    Apparently Denso has switched to a higher density material on the newer impellers. The permanent fix is the same essential LPFP with the impeller made of higher density plastic.
    Just sharing....do with it what you will.
    Cheers.
    Rainoffire, abhamber, HP11 and 23 others like this.
  2. Sep 17, 2020 at 8:25 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Finally some concrete info on why they were failing. Thanks!
  3. Sep 18, 2020 at 4:58 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    CygnusX191, 4x4spiegel and tonered like this.
  4. Sep 18, 2020 at 5:05 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This is all public filings if you look for the recall on NHTSA's Safercar.gov web site. Yes a fuel pump that fails due to fuel exposure. Denso knows what they're doing... most of the time :facepalm:
    Skydvrr likes this.
  5. Sep 18, 2020 at 5:38 AM
    Kaptain_02
    Kaptain_02 2019 OR
    Thanks for sharing. I was curious of the specifics of this failure, good to know.
  6. Sep 18, 2020 at 6:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @MOC221_ posted that up.
    :cheers:
    It all but says that it is a corn fuel problem exasperated by a tolerance issue. Swelling of nylon, etc.
    The funny part is that there are an ass load of these pumps around. It is shocking that they don't have everyone fixed by now.
  7. Sep 18, 2020 at 7:03 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Thanks a ton guy !!!
  8. Sep 18, 2020 at 7:11 AM
    Shellshock
    Iowa
    Wouldn’t be a problem if we didn’t use stupid corn fuel!
  9. Sep 18, 2020 at 7:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is my working assumption. Corn is for eating and drinking, not burning in every damn engine.
    :drunk: :drunk: :drunk:
    hiPSI, CygnusX191, slvrtaco11 and 3 others like this.
  10. Sep 18, 2020 at 7:26 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I had my 1 year service done yesterday and they reminded me of the LPFP recall and I asked when the parts would be available - no idea. He told me they had a few cars people brought in because they didn't feel safe until it was fixed one was a new Landcruiser...I asked what they gave them as a loaner and he said a highlander lol serious downgrade there.
    CygnusX191 and tonered[QUOTED] like this.
  11. Sep 18, 2020 at 7:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just blowing my mind that folks are SOL.
    Although, a loaner is a loaner in my mind. At times in the past, I had to make plans around no loaners being available, or the one that busted an LCA on me backing into a parking spot.
    If folks take a look at @MESO 's recent posts in the OVT TT thread, you'll see exactly what is going on with this swap.
    CygnusX191, Skydvrr and Grossomotto like this.
  12. Sep 18, 2020 at 7:37 AM
    Timetraveler66
    Timetraveler66 Well-Known Member
    You can google and that same info is there. A friend of a friend told me that
  13. Sep 18, 2020 at 7:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For additional info on the actual work:
    Also, @MESO . How hard was the top ring to get loose / off?
  14. Sep 18, 2020 at 7:42 AM
    Timetraveler66
    And Subaru same years also has the same fuel pump recall.
    CygnusX191 likes this.
  15. Sep 18, 2020 at 7:49 AM
    skiploder
    FZJ80/XJ LS swap
    This place .... for fuck’s sake.
    If I had googled it, I would have gladly taken credit for doing the research and would had posted a link.
    I didn’t. I asked a casual acquaintance who is a service manager who did whatever work was involved in answering my question and got back to me. No badge of honor in doing that. No inside secret source...no deep throat, no Hero of TW medal....just contributing to common knowledge.
  16. Sep 18, 2020 at 7:55 AM
    MESO
    State of Jefferson
    It was on there pretty darn good. I ended up using a large flat head and hitting the edge with a dead blow to free it up.
  17. Sep 18, 2020 at 7:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! Just curious should this come up down the road.
    I do like how you didn't drop the whole tank.
    :cheers:
    CygnusX191 and uploadadventure like this.
  18. Sep 18, 2020 at 7:58 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    This ^ or a chisel and hammer will do the trick. There is a fancy tool that goes around it to twist it off.
  19. Sep 18, 2020 at 8:20 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Sad that I can only like this once.
  20. Sep 18, 2020 at 8:42 AM
    Tacoma091919
    Tim
    2019 OR DCLB
    Yikes this is the ring on the fuel tank to access the pump? I'd want to use a brass or cobalt tool to avoid sparks. Would be worse than singed eyebrows if the fuel vapors ignited from a spark.
