Info you may want to hear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nailersniper, Mar 21, 2017.
  1. Mar 21, 2017 at 12:26 PM
    nailersniper
    nailersniper [OP] Well-Known Member
    2017 Limited double cab
    I did the following to my 2017 Limited DC; 2.5" front lift, 2.0" rear lift, went from 30.5" tires(265/60/18) to 32" tires(275/65/18).
    What has surprised me is the following; my transmission shifting has improved dramatically. Previously, I had the shifting problems that have been mentioned many times here. Now, it is a pleasure to drive. I don't know why. Does anyone have an opinion?
    George1441 likes this.
  2. Mar 21, 2017 at 12:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    Because you changed the final gear ratio with the tire change. The transmission is no different, but the RPM ranges you use for the way you drive are.
    Put your old size back and it will be just like it was before.
    cblow5 and boynoyce like this.
  3. Mar 21, 2017 at 12:35 PM
    nailersniper
    Does that mean the RPM ranges before were incorrect? or these are just better for the new tires?
  4. Mar 21, 2017 at 12:38 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Down side is you probably took a ~3mpg hit over the life of the vehicle with this tire size and are putting more strain on driveline and steering components with out of whack geometry.
  5. Mar 21, 2017 at 12:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    No. It just means you found a band aid for a boo boo. ;)
    There are a few other threads around similar in nature, so your results aren't totally surprising.
  6. Mar 21, 2017 at 12:46 PM
    nailersniper
    You may be right, but after 2 weeks my mpg has only suffered slightly, maybe because it isn't shifting as much. As to the strain on components and out of whack geometry, I feel and hear nothing out of the ordinary....so far.
  7. Mar 21, 2017 at 12:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    Have you GPS'd your new speedo error rate, then applied that % variance difference to your calculations?
  8. Mar 21, 2017 at 12:49 PM
    smitty99
    Scottsdale
    It is designed to shift more to accommodate better fuel economy staying in low RPMs. This is annoying, yes but there is a purpose behind it. Now your truck sense a heavier load trying to turn the larger tires and thus will hold gears longer.
    James_Bond likes this.
  9. Mar 21, 2017 at 1:08 PM
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    If your speedometer if off how do you calculate your fuel use? The onboard computer would also read goofy as well as the trip meter.
    I swapped tires and checked my speed w/ a GPS, mile markers and a few radar speed signs to verify my speed but wondering how you know you havent really dropped MPG from stock.
  10. Mar 21, 2017 at 2:06 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    The extra weight will hurt your mpgs. The taller tire will have the effect of giving you a taller final drive ratio and would improve mpgs.
    The taller tire will also trick the computer as it doesn't read mileage correctly anymore. Basically the calibration of the speedometer and odometer is off...... unless they calculate using GPS (which I don't think cars do this yet).
  11. Mar 21, 2017 at 2:10 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    my neighbor claimed the same results after lift and bigger tires. said tranny shifts much smoother than it did before.
  12. Mar 21, 2017 at 2:12 PM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2011 Land Cruiser
    Easy. Use a tire calculator to determine the difference in tire size, then add the applicable difference in miles before dividing my gallons.
    https://www.tacomaworld.com/tirecalc
    In this case, OP will travel 5.08% more miles than calculated on the odometer. So if the odometer shows 200 miles, he has actually travelled 210.16 miles...
  13. Mar 21, 2017 at 2:13 PM
    bamma
    Spokane, WA
    In my 4th Gen 4Runner I found the computer estimate was more accurate after I added bigger tires (the computer overestimated at stock).
  14. Mar 21, 2017 at 2:15 PM
    bamma
    Spokane, WA
    The speedometer and odometer work off of different systems (older cars were tied together). Most modern cars MPH are slightly lower than actual speed. Odometers are pretty accurate, and when they aren't there have been lawsuits.
  15. Mar 21, 2017 at 3:13 PM
    smitty99
    Scottsdale
    Taller Tire improves MPGs in some conditions but not in others. It will kill you in stop & go situations and city driving. Only way it really helps is say on a long flat stretch doing 55mph. Go too fast (outside the "sweet spot" for the gear and tire ratio) now the engine is pushing harder to keep those babies turning.
  16. Mar 21, 2017 at 4:27 PM
    nailersniper
    That's exactly what I calculated!!
