Informal test of my stock springs...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Mar 1, 2011.
  1. Mar 1, 2011 at 5:30 PM
    JKD
    JKD [OP] Well-Known Member
    I've been curious what the spring rate is for the rear suspension on my stock '09 Access Cab. It has the original 3-leaf springs (nothing at all has been replaced or added in the suspension). I drove around with about 500 pounds of stuff in it over rough roads last December and never felt it bottom out, which seems to be completely opposite to what so many people here say.
    I had 180 pounds of sand in the bed of the truck for the winter. I'm pulling it out for now...no snow forecast for at least a week. I took measurements from the ground to the wheel well lip at the vertical axle center line. The ground wasn't perfectly level, so this isn't a perfect test, but here's the measurements.
    With 180 pounds of sand in the bed: 36 1/4"
    With 120 pounds of sand in the bed: 36 7/16"
    With 060 pounds of sand in the bed: 36 1/2"
    With 000 pounds of sand in the bed: 36 9/16"
    A linear fit to that data works out to a 600 pound per inch overall rear sag rate, or 300 pounds per inch on each side. This is within the range of what I think is reasonable for a normal vehicle. (Even just using the first and last data points it is 576 lb/in).
    At that spring rate, loading the bed with the full rated capacity of my access cab (minus a 180 pound driver) would sag the rear suspension two inches. Nowhere near resting on the bump stops. What's our suspension travel in the back--five inches? Should take 3,000 pounds to push it down to full travel. I can sure see why it didn't squat or ride bad with a few appliances in the bed.
    Someday I'll repeat the exercise on level ground with a wider range of weights and get it higher into the load range.
    YMMV.
  2. Mar 1, 2011 at 5:36 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Nice I think my leaf springs will break with any weight. My truck is only 1 year old and the eyes on my leafs already face the ground!
  3. Mar 1, 2011 at 5:38 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    my stock leafs are out!!!!
    well not yet but planned to be.....they are negative arching at me :(
  4. Mar 1, 2011 at 5:42 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Did you load the bags right over the axle?
    At the front of the bed, they'll distribute weight onto the front springs.
    At the back of the bed, they'll *unload* the front springs (cantilever effect) and increase compression.
  5. Mar 1, 2011 at 5:45 PM
    JKD
    They weren't completely over the axle, but they weren't stacked at the front of the bed.
