Information on RCD lift
Discussion in 'Suspension' started by ktmrider, Jan 2, 2010.
  1. Jan 2, 2010 at 5:11 PM
    ktmrider
    ktmrider [OP] Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    So i contacted Down south motorsports (I highly recommend buying everything from them) and i am ordering my 4 inch RCD lift on monday WOOOT:eek:! while i was talking to them i did ask some questions about getting 6 inches out of the lift using 6 inch coilovers, and they told me
    so eventually when i have the cash i will upgrade to some icon/king/pro-crap 6 inch coil-overs and stuff some 35s with better ground clearance then any of the other drop bracket lifts.
    This is my question when i was ordering i asked them if they could give me a smaller block then the 4 inch one provided along with the AAL, what i want to know is how much lift i want in the rear to fix the rake. I know on Peejays truck its lifted 4 inches front and rear and the rake is still there so i am thinking to fix my rake i need a 23/4 to 3 inches in the rear but idk:confused::confused::confused:.
  2. Jan 2, 2010 at 5:34 PM
    ktmrider
    Junk
    mc-bump
  3. Jan 2, 2010 at 7:29 PM
    ktmrider
    Junk
    double-bump
  4. Jan 12, 2010 at 11:26 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    You can get different size blocks from 4WP. But I really doubt that the block you get from RCD will be a 4" block.
    RCD is just a ProComp "knock off" lift. They basically copied the Procomp kit. I really wouldn't be surprised if ProComp makes that kit for RCD.
    I see you load 2 bikes in the rear of your truck? The suspension will be too soft for that much weight. You'll need some type of load helper.;)
  5. Jan 13, 2010 at 7:16 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    does the rcd lift effect the payload?
  6. Jan 14, 2010 at 3:12 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    the rcd lift doesnt effect payload or towing capacity
  7. Jan 14, 2010 at 3:14 PM
    ktmrider
    Junk
    no but towing with the block is going to sag your truck like hell
  8. Jan 14, 2010 at 3:24 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    this is true
  9. Jan 15, 2010 at 5:45 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ok just pm me when you do it
