Information on Spyder OEM fog light install.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WGyde91, Jan 22, 2017.
  1. Jan 22, 2017 at 6:28 AM
    WGyde91
    WGyde91 [OP] Member
    Wes
    2016 SR utility 4x4
    Rough country level Spyder OEM fog 3” total stance
    Looking for anybody whos installed the OEM fog lights on the SR utility. The directions are complete garbage. Essentially I need a underdash wire diagram.
  2. Jan 22, 2017 at 8:44 AM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Looks like any basic set up after market fog light to me.....under dash wires would go to your ignition fuse with a add a circuit 10 amp lower 5 amp upper to power your switch light, grounds to frame or negative battery terminal and power lead(s) to your positive terminal. Turn on truck, push switch, lights on, push switch lights off...turn off truck, no worries on battery drain... search this.....www.tacomaworld.com/threads/2016-toyota-tacoma-fog-light-mod-step-by-step-picture-heavy.403875/
  3. Jan 22, 2017 at 8:54 AM
    WGyde91
    WGyde91 [OP] Member
    Wes
    2016 SR utility 4x4
    Well this has a full harness, I have two open wires. Ignition and power. That post you make your own internal harness. This is ready to go. The wires are supposedly color match but I spent a good hour under the dash last night with a test light. Being I'm not trying fuck my warranty over I need to double check before I add into the pre existing wires.
  4. Jan 22, 2017 at 8:57 AM
    Storman
    South Western PA
    Don't blame you there. Is this going into the ECM for your turn signal stalk ?
  5. Jan 22, 2017 at 9:02 AM
    WGyde91
    WGyde91 [OP] Member
    Wes
    2016 SR utility 4x4
    Negative separate switch on left dash. Oe switch. Popped right in.
