Information request how much should I budget for some work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DR_CA68, Feb 23, 2022.
  1. Feb 23, 2022 at 1:40 PM
    DR_CA68
    DR_CA68 [OP] Well-Known Member
    Dean
    San Jose
    08 TRD SPORT SHORTBED DC
    trying to keep stock
    Hi Folks
    I'm in San Jose and would like to start budgeting for some work.
    Would anyone have any ideas as to the cost for replacing the hoses, belts, and idler for a 2008 DBl Cab v6 prerunner?
    I've done work in the past like on suspension, but am intimidated with the belt and adjusting the tension.
    Thank you in advance.
    Than
  2. Feb 23, 2022 at 2:14 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You should just call your mechanic and ask. It’s different for everyone based on where they live and who they take it too
  3. Feb 23, 2022 at 2:18 PM
    DR_CA68
    Dean
    San Jose
    Thank you, I shall do so
  4. Feb 23, 2022 at 2:54 PM
    Waasheem
    Waasheem
    2007 xrunner
    Search and you'll find plenty of how to instructions in here. I looked at some, it doesn't seem all that difficult. I thought I'd need to do some pulleys but it was just the belt. If you're able to do suspension work, belt & pulleys shouldn't give you problems. I personally don't like to do suspension work, heard horror stories about flying springs.
    DR_CA68[OP] and Ferball like this.
  5. Feb 23, 2022 at 2:56 PM
    DR_CA68
    Dean
    San Jose
    Thank you for your vote of confidence.
    I may try the tasks, just concerned because the last time I did replace some belts, during the test drive I learned the belt was too tight.. ended up having to be towed because the tension caused the belt to be too tight.
  6. Feb 23, 2022 at 3:03 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    I believe that your truck has only one belt and you don’t even have to tighten it so you can’t make that mistake again.
    vtown, DR_CA68[OP] and Gunshot-6A like this.
  7. Feb 23, 2022 at 3:05 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Yeah, the tensioner pulley should take care of all that.
    vtown and DR_CA68[OP] like this.
  8. Feb 23, 2022 at 3:16 PM
    DR_CA68
    Dean
    San Jose
    Thanks..
    I'll be having some reading to do..
    Appreciate your comments
    Hooligans likes this.
  9. Feb 23, 2022 at 3:47 PM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    another vote to DIY. The tensioning the serpentine belt is super easy on the 4.0, it is automatic. Put socket on the tensioner bolt, turn to remove tension, there's a hole you can stick a screwdriver or punch in to hold it in the loose position. Install new belt, turn socket, pull out the punch and let it re-tension the belt.
    Might as well check the condition or just plan to replace the idlers while in there, they aren't too expensive to replace and they usually start to make noise after 100K miles. One word of caution, replacing the entire tensioner itself is a more involved project. I bought it to replace while in there and it's a PITA. AC compressor has to be pulled partially out of the way, and the bolts are a bitch to get too. I ended up not swapping it out. Believe I just swapped the idler on it and left the tensioner. (pretty sure this tensioner idler is reverse thread too)
    possible usefull thread: https://www.tacomaworld.com/threads/serpentine-belt-replacement.9268/
    reference video:
    https://www.youtube.com/watch?v=UHag7j2OP14
    Ferball and DR_CA68[OP] like this.
  10. Feb 23, 2022 at 3:49 PM
    DR_CA68
    Dean
    San Jose
    Thanks for the heads up on the replacement as well as including the video
  11. Feb 23, 2022 at 3:53 PM
    vtown
    CT
    I added a link to a thread I referenced when I did mine. Like some of the guys in there, I also recommend OEM belt and pulleys.
    DR_CA68[QUOTED][OP] likes this.
  12. Feb 23, 2022 at 3:54 PM
    Waasheem
    Waasheem
    2007 xrunner
    Luckily there's no adjusting. It has a tensioner, twist as if loosening the pulley bolt, I think. There's supposed to be a place to stick a pin or something to keep it in place.
  13. Feb 23, 2022 at 4:02 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    If you diy, don't forget the beer :cheers:
    DR_CA68[OP] likes this.
  14. Feb 23, 2022 at 4:06 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I'd cross-post this here to get an answer more specific to San Jose if you don't want to DIY: https://www.tacomaworld.com/forums/northern-california.42/
