Ingnition coil #6 misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hmmckinn, Sep 12, 2025 at 11:20 AM.
  1. Sep 12, 2025 at 11:20 AM
    Hmmckinn
    Hmmckinn [OP] New Member
    Friday
    Hello friends. Need some feedback on my 2004 tacoma SR5 V6. Been have coil 6 misfire over for a min. Ive replaced spark plugs wires and coils. Replaced everything. Still misfiring on # 6. Any suggestions on what next thing I should check? Thank you
  2. Sep 12, 2025 at 11:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A compression test, followed by an injector test would be my next check.
    chasetheCarguy4x4 and t0p_d0g like this.
  3. Sep 12, 2025 at 11:38 AM
    Hmmckinn
    Friday
    Oh okay now is that something I can do or a shop?
    Thank you kindly for your feedback
  4. Sep 12, 2025 at 12:26 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Does no. 6 misfire only when hot but runs fine on cold start?
    How many miles on engine?
  5. Sep 12, 2025 at 1:18 PM
    Glamisman
    Glamisman Well-Known Member
    Yes you are capable of diagnosing this yourself. Both Autozone and O'Reilly's have loaner tools. In addition you will need some basic tools, a 3/8 ratchet, some extensions and a spark plug socket. If you dont have these tools can you borrow them? If not, buying them for a one time job mignt not make economic sense. If you decide to take it to a shop and they do preform a compression test and there is a problem, have them preform a cylinder leak down test too, this will point to where the compression is going.
    If the compression tests are OK then I would suspect the #6 injector is at fault. This is a bit more difficult to diagnose. Usually people will start throwing parts at the motor hoping that it isnt an injector, the ones that work correctly are not cheap but it seems that replacing the injector fixes the mystyrious (sp?) misfires. The other thing to think about is what is called proximity of repairs. You are paying for the labor to diassemble to get to the injector and while you are there, replace the other 2 if your budget allows. All 6 injectors are of the same age and it would be a real pisser to have to pay for a second injector on that side 3 months later.
    Any other questions or concerns... do not hesitiate to ask, there are no dumb questions.
    Cascadesubtaco likes this.
  6. Sep 12, 2025 at 4:10 PM
    Hmmckinn
    Friday
    Glamisman im having a hell of a time figuring out how to reply on here. Okay thank you so much that was really helpful. I'm going to run over to O'Reilly's. The check engine light was on when I bought it however the guy said he would take care of it. We've had to put 2 gas tanks on it. Some kind of leak. Ive replaced all 6 spark plugs wires and all 3 cores on the other side. I can smell gas
  7. Sep 12, 2025 at 4:12 PM
    Hmmckinn
    Friday
    t0p_d0g. When I 1st start it seems okay as it idles is when it starts acting weird. 173,000 miles
