Initial setup for ICON/DR coilovers
Discussion in 'Suspension' started by HAWAIICALIVEGAZ, Jul 5, 2011.
  1. Jul 5, 2011 at 5:15 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I tried searching but couldn't find what I was looking for. I just bought a set of DR coilovers (which I heard are the same as ICON?) But eitherway, on the sleeve there is over 3" of threads. Now i'm just trying to make sure i'm understanding them correctly...
    If I leave the adjustment ring at the top (stock height) then I will have "X" amount of down travel but almost no up travel correct?
    If I set it up to where the adjustment ring is as far down as it can possibly go (whatever amount of lift that is) then I will have "X" amount of up travel and almost NO down travel right?
    so how will I know where to set everything? plus i'm assuming i'll have to raise the drivers side to compensate for the "BRO lean" right?
    I've also got the Camburg UCA's as well... NOTE: non of this is installed just yet but will be soon. Thanks
    Shane
  2. Jul 5, 2011 at 5:27 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Shane, Setting the coilovers at the stock setting will give you factory up and down travel. which is 4" each way and no lift from the Coilover.
    Setting the coilovers to 3" of lift will reduce your down travel by 3" so your left with 1" of down travel.
    But, 3" of thread does not equal 3" of lift, it will be a lot higher.
  3. Jul 5, 2011 at 8:43 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    What they said,
    Also just a few things i learned while installing my Icons. Measure your before and after. Also, after you have adjusted your icons the first time. take it around the block and hit a few speed bumps if you can. Come back and remeasure. They have to settle in a bit from you jacking it up and dropping it back down. Wont be its true height untill you take it out of the driveway and back in.
  4. Nov 10, 2011 at 7:13 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    This is a very helpful thread. I just received my spanner wrench through the mail. Last time I measured the threading, it was at 1.5" of thread exposed and my truck was somewhere below 3" of lift.
