Injector Difference 1998 vs. 1999 3.4L Engines
Discussion in '1st Gen. Tacomas (1995-2004)' started by CS_AR, Apr 25, 2019.
  1. Jul 5, 2019 at 12:04 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    I went with a tested and mach flow rated set from
    Motorwest Performance 7851 Alabama Ave Suite 16, Canoga Park, CA 91304 Owner: Martin Diaz (747) 888-9768 https://motorwestperformance.com/
    Set of 6 Fuel Injectors from MotorWest Perfomance - #23250-62040
    CS_AR[OP] likes this.
  2. Jul 5, 2019 at 12:09 PM
    CS_AR
    CS_AR [OP] Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I bet it runs so smooth now. It's always best to have your injectors pre-tested for flow matching. I've got an engine that uses flow matched injectors that runs so smooth that I can balance a nickel "on its side" on the intake manifold while it idles and I rev it up. No shit.
    970btu[QUOTED] likes this.
