Injector PSA: V6 3.4L 5vz-fe 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by FRgeoff, Jul 26, 2021.
  1. Jan 20, 2024 at 12:35 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Alright I'll give this a shot. 145K mile truck. No apparent leaky injectors, no fuel pressure fluctuations, new fuel system parts (OEM FPR/filter) when I had the engine pulled just because, and MotorWest reman brown Aisin injectors with an unknown original mileage.
    I ended up using the original ~130K mile injectors from this truck in my other 5VZ truck after they were rebuilt by MW. That other truck has been fine, which makes sense considering this solenoid failure wouldn't have affected them yet.
  2. Feb 20, 2024 at 1:41 PM
    04Pre_Runner
    Andrew
    Update: Installed the Denso units from MotorWest this weekend. Also had some nice warm weather roll in today (85 degrees) to further assist with testing. In cold weather it rarely occurred due to how quickly the engine cools off.
    So far I’ve had no issues warm starting after letting it sit 30 mins-2 hours. Which was the range I was having issues with before. If I have no issues over the next month I’ll call it fixed.
    Madjik_Man likes this.
  3. Feb 20, 2024 at 3:25 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Same here, no warm starting issues after replacing them. For me it was more like a 5 minute warm restart that felt weird.
  4. Feb 20, 2024 at 7:20 PM
    TacomaTRD4x402
    TacomaTRD4x402 Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
    Sub'd. Rebuilding my truck from the ground up and I'm going to want to install all the best new parts I can for it and was afraid I was going to have to spend hundreds just for new injectors. Thanks OP :thumbsup:
  5. Jul 9, 2025 at 12:32 PM
    explore4days
    explore4days Member
    Oregon
    Black 99 Tacoma X-cab 4x4 TRD,& 4 Wheel Camper
    Reviving an old thread/
    To the OP FRgeoff
    I’m trying to find the injectors you recommended but it’s not a current part number.
    “98-03 5vz denso equivalent lexus rx300 = 23250-20020 or 23250-0A010 “
    This new #23209-0A010 may be a match but I can’t verify the specs are the same.
    Any additional information your aware of would be be helpful to the Tacoma/5vz community. TIA
  6. Jul 9, 2025 at 1:05 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
  7. Jul 10, 2025 at 11:59 AM
    explore4days
    explore4days Member
    Oregon
    The performance numbers are close to OEM. Apparently the lower 24lb improves gas mileage, but the construction appears to be identical to OEM being 2 pc w a POS cap. I’m trying to avoid any injectors with a cap / coil design that regularly fails.
    The main reasons I’m looking for 23250-0AO10 ( or it’s newer #) is its design being 1 pc with identical OEM performance.
  8. Jul 10, 2025 at 12:50 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Injector Rehab has them.
    https://injector-rehab.com/product/...l-eQubG6PU8kWEXlZUyFvLNJ1chDxO5P3CBKUCBeY_H54
