Injector question!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandlefoot, Aug 8, 2024.
  1. Aug 8, 2024 at 3:19 PM
    Sandlefoot
    Sandlefoot [OP] New Member
    La Paz, Mexico
    2012 Tacoma Off Road
    2012 v6 4.0 Liter Completely rebuilt engine with about 7000 miles. The original injectors were put on the new engine :mad:. Should I have the old ones
    rebuilt or just break down and replace them with new. I am leaning to replacing them but need some opinions on which ones are good!!
  2. Aug 8, 2024 at 3:39 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you are going to the parts cannon. OEM Toyota Injectors. Don't get cheap now.
    Dm93 likes this.
  3. Aug 8, 2024 at 4:07 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is there something wrong with them?
    Injectors don't fail very often so I wouldn't worry about them unless you are having an issue.
  4. Aug 8, 2024 at 4:20 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    X2. Run em till you have a problem.
    gotoman1969 likes this.
  5. Aug 8, 2024 at 8:07 PM
    TacoTuesday1
    SD CA
    I had an old car. The injectors were worn. I sent them out to an injector shop to be rebuilt.
    Some people barely even replace the integrated (worn) basket filter.
    An injector shop, which at the time cost like $60-100, was:
    -ultrasonic clean
    -flow match
    -flow test
    -rebuild/replace wear parts like o-rings, pintle cap if applicable, basket filter, etc
    Pretty good. That assumes they have stock for flow matching if needed.
    The only issue with that is downtime. It was a car I was not using at the time so I did have the week or two it took to mail, work performed, return in mail.
    Right now driving my truck daily I don't have that time, unless perhaps I find a viable candidate set like buy a used set for cheaper than new.
    Which I probably wouldn't want to buy new because it's usually expensive, and a lot of money for something that's still basically stock performance.
    Unlike modded/upgraded cars, which usually get upgraded injectors with more flow as part of upgrading it, in which case it does become a spare part before install, and does have that time for servicing to get ready before actually installing, so the car is still driveable
    as the Tacoma is a daily, and not a garage queen 10 miles showroom once a month Sunday car
    also depends on how common it is.
    B6 A4, many enthusiasts. Many people changing to TT 386CC oem injectors. Probably easier to get that serviced in terms of parts supply vs a Tacoma nobody dealing with injectors.
    IDK how sensitive the ECM is programmed to AFR. Or just putting a gauge.
    It should be noticeable if there is an issue, of being rich or lean. If an injector is stuck open, or not spraying enough.
    But I guess that is the idea behind service, is it's not always about stuck open. But more, flow pattern is not what it used to be due to buildup. Though there are also additive products that claim to help that.
    It's just that additives aren't a guarantee. They're a guess. It's not measurable. Flow match is a visible measurement, as is testing pattern.
  6. Aug 8, 2024 at 8:09 PM
    Bishop84
    Bishop84 Well-Known Member
    No issues with it.
    The only thing I change with fresh engines are seals and spark plugs. I reuse everything else if there's no problems.
    Dm93 likes this.
