Injector sizes for 10 psi
Discussion in '1st Gen. Tacomas (1995-2004)' started by Angel707, Jul 9, 2023.
  1. Jul 9, 2023 at 11:35 PM
    Angel707
    Angel707 [OP] Well-Known Member
    Angel
    Thinking of running 10 psi on my supercharger, what size injectors do you recommend? Im thinking of getting 315cc injectors with a 255 lph fuel pump. Just looking for some feedback because ive gotten different answers when looking at different posts/comments online
  2. Jul 10, 2023 at 4:00 AM
    1997tacomav6
    Denver
    Just get an FMU from snpspeed that comes with the correct size plumbing and connectors.
    FMU turn’s your stock injectors 260cc into a 340cc injector and works only in booost.
    And clean your injector as they has a fuel filter on them and high flow fuel pump
    boostedka likes this.
  3. Jul 10, 2023 at 8:31 AM
    Angel707
    Angel
    I wanted to run a haltech 750, just need the money first :boom:
  4. Jul 10, 2023 at 8:38 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I'd go a little higher than 315 if you have engine management. An FMU is a bandaid... An expensive one
    ChargedSHOTaco likes this.
  5. Jul 10, 2023 at 8:39 AM
    Angel707
    Angel
    What cc do you recommend when i do go haltech?
  6. Jul 10, 2023 at 8:48 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Probably somewhere around 450 just so you have some margin
    Also with an FMU don't forget your fuel pump has to work harder so possible flow drops, but with a Walbro 255 I don't think you'd be getting into risky territory with these levels
  7. Jul 10, 2023 at 11:33 AM
    Angel707
    Angel
    Yea I see your selling an FMU, it doesnt let me reply to it though. Just wondering does that only connect into the ecu?
  8. Jul 10, 2023 at 11:51 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    That's not an FMU, that's a piggyback. An FMU increases the pressure of your fuel rail, a piggyback intercepts signals from your MAF sensor and crank sensor to modify them for your ECU
  9. Jul 10, 2023 at 5:54 PM
    1997tacomav6
    Denver
    I was running the FMU before the haltech with stock injectors and now running the haltech with the FMU and stock injectors with duty cycles at 80-90 percent which works just fine
