Injectors 2004 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ambrosia, Jul 17, 2015.
  1. Jul 17, 2015 at 12:25 PM
    Ambrosia
    Ambrosia [OP] Member
    2004 tacoma 3.4 crew cab
    I found out the problem with my crew cab 2004 Tacoma and got it fixed. It was the controller for the electrical control to the injectors. There is a warranty on this part. A $1,400.00 repair that Toyota. Covered all of it. Free to me. So if you car engine does not follow the gas pedal. Take it to Toyota.
  2. Jul 17, 2015 at 12:35 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    please explain more about what these symptoms are and how to recognize them?
    what is the warranty recall or service bulletin number? it should be on your paperwork
    a few on here have been having what they think is TPS problems that may turn out to actually be related to this
  3. Jul 17, 2015 at 1:35 PM
    Ambrosia
    Key. BLANK, KE
    . 2203062020 and 2227162050.
    Cau throttle body W81979.
    Cor R&R Throttle body as per CSP PROGRAM.
    THAT IS ALL ON THE PAPERS.
    drive down a road and no power. The gas pedal. To get power
    I would pump the gas pedal. Almost like having a fuel filter plugged up. But it was elec.
  4. Jul 17, 2015 at 2:26 PM
    keakar
    karl
    louisiana
    hmm, those sound like very different symptoms that cant be confused as other things.
    thanks for the info :thumbsup:
  5. Jul 17, 2015 at 2:26 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The 1st gen Taco TBW systems have long had probs with the TPS and Toyota only sells the complete t-body. Some folks were able to source just just the TPS from Europe, a real pain if I remember.
    Folks initially felt it was a heat problem causing some adhesive or insulation inside the TPS to break down. They were fooling around with bypassing the coolant lines to the t-body.
    I never really kept up with what was going on but it looks like from the OP there is some kind of service "program". This is different from the TPS "wiper and coil" contact getting sketchy.
    I don't remember the symptoms but it was not an idle quality issue.
