Inner Axle Seal HELP
Discussion in 'Technical Chat' started by 1Falconer, Sep 17, 2011.
  1. Sep 17, 2011 at 12:02 PM
    1Falconer
    1Falconer [OP] New Member
    Ron
    Oregon
    '06 Extended Cab 4wd
    backlit 4wd selector, air bags, 2 1/2" lift, K&N intake, 120V by-pass and plugs in cab, tinted glass all around
    After some research I have found that the guy behind the parts counter didn't know his S*#T :brianr: Tried to convience me that I had to buy a complete rear hub in order to replace a axle seal. His reply was "They don't make 'em like they used to". I'm old but NOT stupid :eek:. My question does anyone have a part number and manufacturer by any chance for the inner axle seal??? Also if anyone can help me out with the size of the "O" ring I want to replace that also instead of cleaning it and putting it back in. Tearin' apart and putting back together is the easy part finding the correct part is the hard part. Thanks in advance to any and all help.
  2. Sep 17, 2011 at 3:07 PM
    Tacoma Mike
    Southern Maine
    Walk right into your local dealer. Right in stock more than likely. correct size and everything. Not so hard. If not local then I'm sure others have done this and lots of guys take down the part numbers. Give them a little while and i bet you'll have them numbers.. If that was a dealer then he's an idiot.
    OH Welcome :wave:
  3. Sep 18, 2011 at 12:14 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I just bought 2 of what I believe to be inner axle seals. I'll see when I get the parts. I can grab you a part number then.
  4. Sep 19, 2011 at 3:26 PM
    1Falconer
    Ron
    Oregon
    Thanks for the input and the Welcome. I used to be known as Goshawk out here but due to my lack of activity they wiped me off their books so I had to re-registar using a different name.:eek:
  5. Sep 19, 2011 at 3:28 PM
    1Falconer
    Ron
    Oregon
    Thanks to those that replied to my question and thanks for the Welcome also. I used to be known out here as Goshawk but due to my lack of activity they wiped me off their books so I had to re-register with a completly new name.
    :D
