Inner tie rod 6” lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mitch_2234, Nov 10, 2020.
  1. Nov 10, 2020 at 4:07 PM
    Mitch_2234
    Mitch_2234 [OP] Active Member
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    I have a 6” fabtech kit and 34” inch tires. I’m needing to replace my outer tie rods, (most likely inner too) the boots are blown out and one is easily moved by hand. Does anyone have any recommendations on what kind of tie rod to get ? Should I get a heavy duty tie rod? If so I’d like to hear recommendations on that.
    Back2mud likes this.
  2. Nov 10, 2020 at 4:20 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Moog is good, if your banging around that hard the rack will not be far behind.
  3. Nov 14, 2020 at 8:38 PM
    Back2mud
    Back2mud Member
    2009 Grey DC Tacoma 4x4
    6" BDS Lift w/ 35s ARB front bumper w/ winch Body Armor rear bumper w/ spare tire mount ARB Safari Snorkel
    I created an account just so I could comment and track this thread. I'm in the same situation with the same questions. 6" BDS lift, 35s, and need new tie rod ends.
  4. Nov 14, 2020 at 8:43 PM
    Bishop84
    Bishop84 Well-Known Member
    2008 you likely need an entire rack, check the boots for oil. Also check the play in the rack.
