Inner tie rod cost
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Sep 6, 2019.
  1. Sep 6, 2019 at 11:05 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's all pretty standard stuff to replace on an older truck. Bet it drove like new afterwords. Control arm (and leaf spring) bushings will help seal the deal though.
    Even if you go nuts and get Kings and such, it's still less than a a year's worth of car payments on a new truck...
    CS_AR[QUOTED] likes this.
  2. Sep 6, 2019 at 12:56 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    It sure drives like a new one now.
    jbrandt[QUOTED] likes this.
  3. Sep 6, 2019 at 6:23 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Did you check Trivago?
  4. Sep 6, 2019 at 7:11 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I ordered mine from Lowrange off-road. Made in Japan, 555’s I think. Been good for a year now.
  5. Sep 7, 2019 at 5:55 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    I got the pair for $150 total (both sides)
  6. Sep 12, 2019 at 10:51 AM
    vettehigh
    Jon
    Upstate, NY
  7. Sep 12, 2019 at 10:53 AM
    eon_blue
    Azusa, CA
    Talking about just the outer tie rods? I got mine from Toyotaparsdeal.com for $47 each.
    edit - nevermind I see you're referring to the inners, I went with 555 branded ones from Lowrange Offroad for way cheaper than OEM.
  8. Sep 12, 2019 at 10:54 AM
    vettehigh
    Jon
    Upstate, NY
    Need inner tie rods
  9. Sep 12, 2019 at 10:56 AM
    eon_blue
    Azusa, CA
    yeah I just edited my post above, I went with the Moog 555 branded inners for way less $$ from LROR. Toyota parts deal has the inner tie rods for $153 each, that's crazy
    Luv my yota likes this.
  10. Sep 12, 2019 at 10:57 AM
    vettehigh
    Jon
    Upstate, NY
    I know...why the hell they so expensive?
  11. Sep 12, 2019 at 10:59 AM
    eon_blue
    Azusa, CA
    Makes no sense to me, it's a pretty small chunk of metal. When I compared my old OEM ones to the 555 ones I installed they were identical, I have no worries about the 555s being inferior.
    The outer tie rods I feel it's more crucial to go OEM because those more commonly break on the trail.
  12. Sep 12, 2019 at 11:00 AM
    vettehigh
    Jon
    Upstate, NY
    Where can I get my part number in 555's?
  13. Sep 12, 2019 at 11:04 AM
    eon_blue
    Azusa, CA
  14. Sep 12, 2019 at 11:06 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I installed a set of these about a year ago, all good!!
    eon_blue likes this.
  15. Sep 12, 2019 at 11:08 AM
    #35
    jbrandt
    Justin
    The 555's I have seemed pretty identical to the OEM ones I removed. It's not like the OEM uses thicker metal, as far as I can tell. There's also the school of thought that you want your weak point to be the thing that is easily replaced.
  16. Sep 12, 2019 at 11:09 AM
    #36
    vettehigh
    Jon
    Upstate, NY
    Luv my yota and eon_blue[QUOTED] like this.
  17. Sep 12, 2019 at 11:11 AM
    #37
    vettehigh
    Jon
    Upstate, NY
    Wonder if anyone has info on the quality and strength between OEM and 555?
  18. Sep 12, 2019 at 11:11 AM
    #38
    eon_blue
    Azusa, CA
    It's just a hunk of metal with a joint and a stake washer, the OEM price is crazy for that if you ask me. You can get the OEM lower ball joints for about the same price and those are more material/more design to them.
  19. Sep 12, 2019 at 11:12 AM
    #39
    eon_blue
    Azusa, CA
    Generally 555 is the go-to brand for aftermarket on here, if not OEM. I am a proponent of using OEM for pretty much everything but some things like the inner tie rods I just can't stomach how much $$ it is. If they were a known failure point then I would think differently, but I think the 555s are more than fine for this application.
  20. Sep 12, 2019 at 11:13 AM
    #40
    vettehigh
    Jon
    Upstate, NY
    I got my OEM ball joints for $105 each
