Input from spacer (wheel) guys?
Discussion in 'Wheels & Tires' started by Fiend13, Jan 4, 2013.
  1. Jan 4, 2013 at 9:47 AM
    Fiend13
    Fiend13 [OP] Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I have some 1.25" spacers to put on but not sure if I want to or not. Read that you shouldn't use impact guns when rotating them and I doubt guys at a tire shop would care if I said not to so been a little iffy on putting mine on. I know plenty of people on here run them but just wondering what y'all do when it comes to rotating and balancing the tires. That's why I don't want to but I have the stock O/R rims with 285's with about .5" of clearance between the tire and UCA and that's why I want to. Thanks for the help!
  2. Jan 4, 2013 at 9:49 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The only company i'd be safe using when it comes to wheel spacers is Spider Trax.
  3. Jan 4, 2013 at 9:52 AM
    Fiend13
    Chad
    That's what I have, Spidertrax 1.25"
  4. Jan 4, 2013 at 9:53 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If it ain't broke don't fix it.
    1/2" is plenty of room.
    Why add another failure point to the truck and increase the chances of wearing out parts when it is not needed?
    Also if your worried about some shop screwing up your truck the easy fix is to rotate your tires yourself. A little manual labor never hurt anyone (if your physically capable).
  5. Jan 4, 2013 at 9:56 AM
    krimson
    krimson Nothin
    TRD Off Road
    Good :thumbsup:
    If you're worried about idiots in a shop screwing up the wheels on your truck, just do it yourself.
  6. Jan 4, 2013 at 10:16 AM
    Fiend13
    Chad
    Rotating I have no problem with but I don't have a way to balance them myself. Just figured 1/2" of clearance would be too close to comfort when offroading. Nothing hard though, just trails and dirt/rocky roads to campsites, things like that.
  7. Jan 4, 2013 at 10:21 AM
    Fiend13
    Chad
    Another reason I ask is because I'm unsure about what rims to get as far as backspacing goes. I've read the sticky but it's almost as if it's a foreign language to me :pout: plus I like my stock rims now that they're black.
