Input on 2nd gen rear suspension upgrade
Discussion in 'Suspension' started by BaconPower, Nov 12, 2020.
  1. Nov 12, 2020 at 8:23 AM
    BaconPower
    BaconPower [OP] Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    Getting a new set of leaf springs.
    • Will I need longer shocks?
    • Will I need a carrier bearing drop?
    Truck is 2013 DCSB TRDOR.
    New leaf spring coming in is Deaver expedition stage 2.
    Based on discussion with Deaver, rear lift would be 1.5 to 2 inches.
    • Would the stock Bilstein 4600 be long enough for this (worst case) 2 inch lift? Or do I need add longer shocks like the 5100s?
    • Would the steeper angle (lift + short bed) put angular stress on the carrier bearing, that require a carrier drop? If so what shims/angle/setup is preferable for the drop?
    Thanks.
  2. Nov 12, 2020 at 10:07 AM
    state48offroad
    state48offroad Well-Known Member
    it would be best to get a new shock. I ran the Deavers with a stock shock for a little while and it was very limiting in terms of travel, everytime i would flex a little, the rear shocks would fully extend pretty violently and it restricted my down travel(droop) so i went with an aftermarket shock and it gained almost 2in of droop and helped a lot climbing over rutted areas and whatnot, keeping the rear tires planted on the ground.
  3. Nov 12, 2020 at 10:56 AM
    BaconPower
    Portland, OR, USA
    Which aftermarket stock did you get?
  4. Nov 12, 2020 at 11:01 AM
    state48offroad
    I got the Kings! I went with the Tundra rear shocks for more travel but the hose fittings are different than tacoma so i had to cut out a lot of the top pocket on one side but they work well. The Tacoma Kings #25001-121A are longer than stock and will give you more travel. I believe they have a 8.5in stroke
  5. Nov 15, 2020 at 10:49 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Just give https://accutuneoffroad.com/ a call and they can tell you what you need. They may not have what you want unless you step up to at least Fox 2.0's
