Input shaft bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by RT831, Mar 5, 2012.
  1. Mar 5, 2012 at 5:58 PM
    RT831
    RT831 [OP] Member
    Santa Cruz
    White 4x4 SR5
    is the input shaft bearing worth replacing?
    and does it do any harm if the bearing is bad?
  2. Mar 5, 2012 at 6:14 PM
    RT831
    RT831 [OP] Member
    Santa Cruz
    White 4x4 SR5
    input shaft bearing whining is it worth replacing
    and is it doing any harm?
    thanks
  3. Mar 5, 2012 at 6:17 PM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes. If it goes, it has the potential to run the input shaft of the tranny and the tranny itself.
  4. Mar 6, 2012 at 4:46 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Yes. Replace it asap. When squeakey bearings fail, it gets ugly fast!
  5. Mar 6, 2012 at 10:31 AM
    RT831
    RT831 [OP] Member
    Santa Cruz
    White 4x4 SR5
    i talked to a few mechanics and they said no to worry. i have 119000 on it and they said just replace it when i need to replace the clutch.
  6. Mar 7, 2012 at 5:34 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If it was my truck, I would be quickly getting money for a clutch kit. 120k is the low end for replacing the clutch, but with a bearing going bad it's a good time to get it done.
    They say not to worry, but it's your truck and your risk. They won't have to pay for it either.
  7. Mar 7, 2012 at 8:47 AM
    pittim
    pittim mittip
    Respect your elder gen.
    Pink slider.
    If it's not making a sound dont worry about it. They'll start to squeal and then the fail, at least thats my experience.
    FWIW there was a tranny bearing squealing on my truck (dont know if it was pilot or throwout) but the squealing stopped and then my clutch started slipping. But last weekend my truck got a new clutch flywheel and bearings
  8. Mar 7, 2012 at 9:44 AM
    dorkmagus
    dorkmagus Well-Known Member
    Shane
    Bentonville, AR
    2012 Double Cab Tacoma TRD OR
    Wait, are you talking about a throwout bearing or input shaft bearing (inside the trans)? If it's the input shaft bearing then you have to open up the transmission to replace it. It will be loud when the clutch is engaged and will be quiet when the clutch is disengaged.
  9. Mar 17, 2012 at 11:17 PM
    RT831
    RT831 [OP] Member
    Santa Cruz
    White 4x4 SR5
    here is exactly whats happening.
    Start the car. put it in neutral(staying still)
    after a few seconds i hear a little squeaky bearing(whitsling kinda)
    barley put foot on the clutch pedal and its gone.(like a throw out bearing)
    push the clutch to the floor all the way and it this other wooooooo ing sound is gone.
    take the clutch out and the woooing sound and squeaky bearing sound comes back.
    the truck only has 119000 miles on it.
    thanks. and please no smart a$$ comments
  10. Mar 18, 2012 at 1:05 PM
    EV831
    EV831 Active Member
    ETHAN
    Bay Area
    00 PreRunner TRD
  11. Mar 18, 2012 at 1:22 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Sounds like the throw out bearing
  12. Mar 18, 2012 at 2:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This, & does it whine all the time or in certain gears ?
    Not really sure it matters (mine used to whine noticeably in 5th)
    But jury is kinda out on the longevity of noisy input bearing, some get noisy & go out relatively soon & I've seen some go on thru out the life of the vehicle, I'd change it just because it annoys the hell out of me, not cheap to replace tho'
    It's a $10-$20 bearing with about a $1000 worth of labor to replace....
  13. Mar 18, 2012 at 2:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Just read this, if you're sitting still & this noise is occuring I'd say throw out also..
  14. Mar 18, 2012 at 4:07 PM
    RT831
    RT831 [OP] Member
    Santa Cruz
    White 4x4 SR5
    When I drive I can hear a whine, In all gears but it shifts perfect. And it stops whining when I'm off the gas in gears and coasting.
  15. Mar 18, 2012 at 4:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ok, back to input shaft bearing
  16. Mar 18, 2012 at 8:36 PM
    dorkmagus
    Shane
    Bentonville, AR
    Yeah, I've found that most of the time if you hear it only when the clutch pedal is pressed in (disengaged) then it's the throwout. If you hear it when the pedal is out (engaged) then it's the input shaft bearing. However with the ones I've dealt with it usually sounds more like a box of rocks in your tranny than a whining noise. I work for Honda though and hear it mostly on older civics...haven't heard it on a tacoma.
  17. Mar 18, 2012 at 11:33 PM
    RT831
    RT831 [OP] Member
    Santa Cruz
    White 4x4 SR5
    yeah but at 119000 miles, would the input shaft bearing go out and whine, it seems way to early?
  18. Mar 21, 2012 at 8:14 PM
    EV831
    EV831 Active Member
    ETHAN
    Bay Area
    00 PreRunner TRD
  19. Mar 21, 2012 at 9:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I had an 83' straight axle that had 95k when it started making noise (whining) & finally changed it at about 225k
    annoying , but long lasting
  20. Mar 21, 2012 at 9:36 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    I put 60,000 km's on a squeaky input shaft bearing on my ranger ... no probs
    although i should have protected my investment by replacing it...
    seemed to be fine when I sold it tho.
