Insane Fuel Economy After First DIY Oil Change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Torquemado, Sep 5, 2025 at 1:44 AM.
  1. Sep 5, 2025 at 1:44 AM
    Torquemado
    Torquemado [OP] Well-Known Member
    Heart of Texas
    2020 Sport MGM MANUAL
    For my 40,000 mile maintenance I decided to take on the task myself (with Castrol 0W-20), rather than further enriching the dealership. I of course removed the air dam in the process, and initially noticed the expected one mpg drop in gas mileage (from 16 to 15). Three thousand miles down the road (with the air dam still off), I'm actually hitting numbers close to 18, under the same city driving/daily commute conditions. I'm certainly not complaining here, but wanted to eliminate the possibility that I screwed something up...
  2. Sep 5, 2025 at 1:50 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Well, 15-16 is a little low for a 3rd gen V6, so you’re up to where you should be now. I doubt you screwed something up.
    Jakerou, tonered, Chew and 3 others like this.
  3. Sep 5, 2025 at 5:05 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It's called an anomaly.
    soundman98 and Chew like this.
  4. Sep 5, 2025 at 5:25 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I'm a stock OR (so no air dam) and get 20-21mpg. That's going 60ish up/down roads in Appalachia. I get similar mileage on the highway (little lower in winter). Have been using 0w20 the entire time. Unless you put no oil in or too much and it's not leaking out, there's nothing to screw up.
  5. Sep 5, 2025 at 5:47 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
  6. Sep 5, 2025 at 6:12 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    It’s fine. I average 20-22mpg on the highway depending on traffic and I’m on 33” tires.
    If I hit an exceptionally flat stretch of highway with no traffic, I have done almost a full tank with an average of 24mpg. Nothing weird about your numbers other than maybe being a tad low.
  7. Sep 5, 2025 at 1:24 PM
    Palomar Taco
    Palomar Taco Well-Known Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
    Probably got some better gas somewhere?
  8. Sep 5, 2025 at 2:34 PM
    Torquemado
    Heart of Texas
    Same gas as always. Another possibility i was thinking about would be tire pressure, but that has actually gone down a couple of psi with the coming of cooler weather.
  9. Sep 5, 2025 at 4:23 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Sounds to me like your truck is broken in and starting to balance out the averages.
