Insane MPG?
Discussion in '4 Cylinder' started by maxpower29, Apr 22, 2011.
  1. Apr 22, 2011 at 6:16 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Today I got my Scanguage installed, and we drove all day. Truck is brand new with 450 kms (280 miles) and we drive over half that today. I drove the usual trips we take and routes just to test out the MPG we would get. I was fairly cautious but still lots of room to improve. Started/turned off the motor 3 times, and idled a few time. I drove about 85% city/15% highway with some hills but nothing too serious.
    At the end of the day it said I averaged 28.2mpg. (US gal)
    Is this right?? That seems insane. I didnt even baby the hell out of it. Stock everything other then the 2nd filter delete (afe in the mail still)
    Is it because of the gas we use that has no ethanol?
  2. Apr 22, 2011 at 6:20 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
  3. Apr 22, 2011 at 6:24 PM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Not accurate everyone else hit it right on, you need to fill it up about 4 -5 times. You will be getting around 20 - 22 mpg. Even after I change my tires it took a few fill ups for my mileage to become accurate again.
  4. Apr 22, 2011 at 6:30 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I thought so. I did set it up as close as possible. But I expect it to go up. We shall see..
  5. Apr 24, 2011 at 1:08 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    On my 7th and 8th trip today here were the numbers
    7th- 40-50 kms = 24.5 mpg (alot of up hill)
    8th - 40-50 kms = 30.2 mpg (back home)
    Im telling you guys, This is the mpg I keep getting. Anywhere between 24-30 depending on how easy I am on the truck, and the road cconditions. Will this continue? I have over 300 kms on the scanguage so far
  6. Apr 24, 2011 at 3:39 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    My Ultraguage calibration factor is 1.12. Without doing the calibration my mileage would be about 27 MPG, instead of the actual 24.4 MPG that I really get. BTW are you figures USA gallons or Imperial gallons.
  7. Apr 24, 2011 at 3:42 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    US gallon. All my units are american. MPG, MPH, and everything. What is this calibration you speak of?
  8. Apr 24, 2011 at 3:55 PM
    91r100gs
    Dan
    Kansas City area
    The calibration on the Ultragauge is where you input the actual Gallons put in the tank. The 4 cyl Tacoma has no fuel level sensor in the tank that reports to the OBDII port. Therefore, at least on the Ultraguage you need to calibrate your Scanning guage by entering the amount of fuel put in the tank for the first few fillups. Maybe someone with a Scangauge can tell you how to check the calibration of your Scangauge.
    Post #3 in this thread links to a Scangauge manual and page number to do a calibration for your gauge
  9. Apr 24, 2011 at 4:00 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Im just reading the real-time mpg and the average mpg for a trip. Nothing to do with putting fuel in it is there?
  10. Apr 24, 2011 at 4:03 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I think the biggest thing is that our gas has no ethanol in it, Im coasting when I can. I change gears at 2000rpm whenever possible. Maybe my scanguage is setup for imperial gallons then? Dont know why. A lot is to do with removing the 2nd filter. SUPER noticeable that Im wasting less gas without it
  11. Apr 24, 2011 at 5:33 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I was going to ask if you were calculating US or Imperial gallons .
  12. Apr 24, 2011 at 5:40 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    everything is US gallons. Im going to update this but I think I may be getting insane gas mileage
  13. Apr 27, 2011 at 10:22 AM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    Like people have said before, it's not properly calibrated. Make sure you know how to set it up, and adjust accordingly every single time you fill up.
    Also, check manually with the pump reading and your odo reading every fill up.
  14. Apr 27, 2011 at 10:31 AM
    OZ-T
    Peter North
    British Columbia
    Miles travelled divided by gallons used at next fill up , it's pretty easy .
  15. May 1, 2011 at 7:40 PM
    frog13
    frog13 Well-Known Member
    On your scangauge initial set up....size of engine(liters)..type of fuel etc. ....it does have you go through and enter this data.
  16. May 2, 2011 at 4:33 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Hand calculated I'm getting 24+ still. My girlfriend also drives it and she's clueless to gas saving. So 25+ would be normal without her I think
  17. May 12, 2011 at 3:14 AM
    ScottyDaug
    ScottyDaug Active Member
    2011 Regular Cab 2.7 4X2
    Just got 27.9 MPG on my last tank. Bone stock 2011 Reg Cab 4x2 I4 Manual.
  18. May 12, 2011 at 3:49 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Nice! I just hit 24.8 with a 17gal fillup
  19. May 12, 2011 at 1:39 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    460 miles so far on this tank and the gas light hasn't come on yet.
  20. May 19, 2011 at 2:27 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes the lack of ethanol in summer blend fuels will increase your mpg, but only by about 5% and as usual that figure depends on how the vehicle is driven. I drive like a sissy and 1 month ago my mpg went from ~22mpg to ~25mpg (just did 436 miles on 17.1 gallons). You still need to calibrate that scangauge... I feel strongly that you should record actual miles and gallons added and do the math until the results match the scangauge consistently.
