Inside door panel fastener - where to find?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oldstick, Jun 10, 2014.
  1. Jun 10, 2014 at 10:33 AM
    oldstick
    oldstick [OP] Medicare Member
    GA
    Anybody happen to know if the small round plastic fastener on the upper front corners of the door panels are a commonly available item, (i.e. the chain parts stores)?
    I broke one and before I go driving around everywhere, I thought I would ask. I know they have the ordinary snap-in type fasteners of assorted sizes, but this one is different. It is two sliding pieces and you just depress the springy center section and it slides right out. (I learned that AFTER snapping the first one to itty bits.)
    Not talking about the clips on the backside of the door panel, but the round plastic one visible inside the truck.
  2. Jun 10, 2014 at 11:01 AM
    oldstick
    GA
    I'll have to go dig up a pic. Someone who has ever taken off the inside door panel (on a second gen) will know what I mean. All you have to do is remove one screw from the arm rest, one screw from the inside door handle and this one plastic clip in order to pry off the door panel.
    Actually I don't for see any problems if this clip is missing but, after seeing how it works, I thought the design was so cool, I have to try and find a replacement.
  3. Jun 10, 2014 at 1:10 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    junk yard
  4. Jun 10, 2014 at 1:14 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Toyota. They sell all the clips. I think I know what part your talking about.
  5. Jun 10, 2014 at 5:43 PM
    HTX
    HTX Well-Known Member
  6. Jun 10, 2014 at 6:49 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yup. Seems to be this.. # 90467-A0016-B2. Have used Camelback a few times myself, although I just go in since its local.
  7. Jun 10, 2014 at 8:49 PM
    oldstick
    GA
  8. Jun 10, 2014 at 11:30 PM
    smgcon
    smgcon Well-Known Member
    Geoff
    Vernon, BC
    2013 DBC
    I bought some at my local auto parts store. They were on a rack with all makes of replacement push pins, clips, window cranks, door handles, etc.
