inside tire wear problem plus shake
Discussion in '1st Gen. Tacomas (1995-2004)' started by yota new.o, Sep 5, 2011.
  1. Sep 5, 2011 at 9:39 AM
    yota new.o
    yota new.o [OP] Well-Known Member
    joe
    klamath falls oregon
    96 tacoma 2.7 sr5
    fabtech dirtlogic coilovers with all-pro a-arms chevy 63" leaf springs billi 5125 12" extended bore shockins in rear headache rack duplicolor bed armor bumpers kc daylighters front fenders corbeau racing seats custom bed rack
    after getting my lift installed and allignment done by les schwab. i have had a shake at 55-60 mph. fron driver side is where i can tell it's coming from. on that same side the inside of the tire is worn better than half of what the outside is. any thoughts on what the problem could be? i did notice some access grease coming from the lower ball joint but nothing that looks to major.
    thanks JOE
  2. Sep 5, 2011 at 9:41 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    btw its a 96 standard cab 2.7 if that helps
  3. Sep 5, 2011 at 9:41 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Get it realigned and have that ball joint checked. sounds like the camber is off.
  4. Sep 5, 2011 at 10:09 AM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    02 4runner 04 solara
    4runner-32x11.5x15 falken rocky mt, tundra king 2.5 coilovers with taco perch, TC UCA, OME rear springs and procomp es9000's, thule roof rack.
    shaking at higher speeds meant the tires were unbalanced in my case.
  5. Sep 7, 2011 at 4:02 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    so balanced my tires which was good all four were jacked up the allignment was pewrfect saw the spec. sheet but it still shakes. the tire wear could be coming from them rubbing are wheel spacers a good idea. and what else could cause the shake thanks guys
  6. Sep 8, 2011 at 5:47 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    What about the ball joint? Did you get it checked? And what size tire are you running?
  7. Sep 8, 2011 at 11:41 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    the ball joint is good and im running a 33x12.50x15
  8. Sep 8, 2011 at 7:52 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Any way you can get some pics of the tire wear? What rim style and size are you running?
  9. Sep 8, 2011 at 10:00 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    Could be your ball joints and/or tie rods. Lift your truck at the LCA and place your hands and 6 & 12 and move the tire. If the tire has play then your LBJ's are bad. Next, place your hands at 3 &9 and move the tire. If the tire has play it's your tie rods. To check your inner ball joints place your truck on the ground, remove the boot from the tie rod and have someone move the steering wheel. If you see the tie rod moving around/play then you know your tie rod is bad.
  10. Sep 9, 2011 at 8:04 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    thanks guys ill get picture up soon of the tire wear
