Insight on suspension upgrades when I get new bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InfamousTonyTaco7714, May 26, 2017.
  1. May 26, 2017 at 2:30 AM
    InfamousTonyTaco7714 [OP] Well-Known Member
    Lucas
    Wilkes, NC
    09 SR5 DCSB 4x4 Timberland Mica
    Borla Catback, 6 inch Pro Comp Stage 1 17x9 Matte Black XD Revolvers, 285/70/17 Radar Renegade R7, Pioneer Double Din, Iron Cross Side Steps, Tactical Armor Group Front Bumper, ARE MX series camper shell, Geared 4.10
    I'm buying a new front bumper next week and am considering doing some suspension upgrades while I'm at it. The guy said the bumper weighs in the range of 120 lbs. I don't want to sag much in my front end because of it and I'm looking into biting the bullit on some 5100's front and rear. The question I have is, do I need to get aftermarket coils as well to compensate for the added weight? Also what kind of coils do you guys suggest?
  2. May 26, 2017 at 2:34 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  3. May 26, 2017 at 2:35 AM
    Lucas
    Wilkes, NC
    What kind of price am I looking at for a good set?
  4. May 26, 2017 at 2:35 AM
    Lucas
    Wilkes, NC
    I'm not very highly educated in suspensions so any info I would really appreciate!
  5. May 26, 2017 at 2:38 AM
    la0d0g
    running for the hills
    For crawling not hauling
    OME springs are about $170
  6. May 26, 2017 at 2:39 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Looks like about $150 for HS Coils. And about $175 for OME Coils.
  7. May 26, 2017 at 2:41 AM
    Lucas
    Wilkes, NC
    Not bad. Cheaper then I expected. I've seen people on here talking about ome 885,886,887. What's the real difference and what should I be getting for what weight I'm adding to it?
  8. May 26, 2017 at 2:41 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
  9. May 26, 2017 at 2:45 AM
    la0d0g
    Spring name/Spring rate (N/mm)/Bar dia/Coil length (mm)
    OME 883 / 103 / 17 / 375
    OME 884 / 103 / 17 / 385
    OME 885 / 103 / 17 / 395
    OME 886 / 115 / 18 / 402
    103 = 588 #/in
    115 = 656 #/in
    stickyTaco likes this.
  10. May 26, 2017 at 2:46 AM
    Lucas
    Wilkes, NC
    Also, as we all know it's frowned upon, but I have a 3 inch readylift spacer underneath the front. Measurements acheived the full 3 inches when I put it on. When upgrading the shocks and coils should I remove this? And also, what would you guys suggest I do to keep the full 3 inches in the front?
  11. May 26, 2017 at 2:47 AM
    la0d0g
    887s are same spring rate as 885s but slightly longer.
  12. May 26, 2017 at 2:47 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Yes you most def should remove the spacer. Combining lift Coils with spacers are death to the shock. You won't have any down travel at all. Talk with Marie at Headstrong and she'll point you in a direction to which coil you should pick to achieve about 3" of lift with your bumper.
    boogie3478 likes this.
  13. May 26, 2017 at 2:48 AM
    la0d0g
    Yes remove it. Any particular reason you want a full 3"?
  14. May 26, 2017 at 2:49 AM
    Lucas
    Wilkes, NC
    Thanks man. I figured I should take the spacer out, just thought it never hurt to ask. I know spacers are frowned upon and all so that's another reason I'd like to go ahead and go with upgraded coils and springs so I could get rid of it and have a much better set up.
    DustStorm4x4[QUOTED] likes this.
  15. May 26, 2017 at 2:50 AM
    Lucas
    Wilkes, NC
    Since I have the full 3 I've come to just love the way my truck looks as it sits now, so I'm just wanting to keep my truck looking the same height, with a better suspension underneath it. And with the added weight I wanna make sure I can still achieve that.
  16. May 26, 2017 at 2:52 AM
    la0d0g
    With 120lb hanging off the front you'll want to get 886s with the top plates then. 887s will get you the lift but over time will sag.
  17. May 26, 2017 at 3:01 AM
    Lucas
    Wilkes, NC
    Will that still give me the 3"? And what setting should I set the billies on to get the 3"
  18. May 26, 2017 at 3:01 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I just spent yesterday after noon looking into this. A combination of 5100s and 886, with a small top plate spacer will get you the lift you need. That being said there is a chance you will need new upper control arms (to be able to align) and diff drop kit. It all depends on the weight of the bumper/accessories, variances in the springs, and variances in the truck.
  19. May 26, 2017 at 3:02 AM
    la0d0g
    It'll be close to 3" it's not an exact thing. Billies always set on 0 with OME since the coil provides the lift.
    DustStorm4x4 likes this.
  20. May 26, 2017 at 3:03 AM
    Lucas
    Wilkes, NC
    According the the seller, the bumper is in the range of 120 lbs
