Inspecting Rust Inside the Frame Using Endoscope. Need your help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rustytaco03, Nov 17, 2017.
  1. Nov 17, 2017 at 6:00 PM
    Rustytaco03
    Rustytaco03 [OP] Member
    Deleted
  2. Nov 17, 2017 at 7:30 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    That's real cool with the scope...I'm not sure how bad that really is...the guys with the experience will chime in soon.
  3. Nov 17, 2017 at 7:54 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Man I'm glad I live in the south.... 01 with zero rust.
    Running Board Man likes this.
  4. Nov 17, 2017 at 8:05 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Pull the bed off and restore the frame :thumbsup:
  5. Nov 17, 2017 at 8:27 PM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    Oh the dreaded frame rust... You're not alone, just remember that!
    Pic 15 and 16 you can see multiple layers of rusted steel...like an onion, it's just gonna keep peeling until it's through to the other side. I would use a small hammer to knock on that area and see if you get perforation.
    And whoever you talked to is full of:crapstorm:... I believe the warranty was extended through this year,given the frame was coated previously by Toyota under warranty.
    Keeping the truck depends on how involved you want to get, in order to get to that loose rust you'll need get into the frame somehow... I was able to take care of the inside rust cause I had to cut out my bad areas allowing access.
    It was worth it to me to fix the issue, but YMMV!
  6. Nov 18, 2017 at 11:04 AM
    Tomato1981
    Tomato1981 Well-Known Member
    Dont take no for an answer at the dealership
  7. Nov 18, 2017 at 7:27 PM
    Rustytaco03
    Thanks you all for your suggestions. I'll keep you guys updated if I get to pull the bed off and repair the frame. I tried calling multiple Toyota dealerships in MN to ask if I'm eligible. To be able to get my frame replaced, I have less than 2 months since 2018 is right around the corner (mine is 2003).
  8. Nov 18, 2017 at 7:30 PM
    Tomato1981
  9. Nov 19, 2017 at 3:29 PM
    Rustytaco03
    Thanks! I'll go over that thread.
