Inspection station Recommendation? RECON ?
Discussion in 'Hawaii' started by John taco, Jul 24, 2016.
  1. Jul 27, 2016 at 9:39 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    no check engine light? you should be fine.
    Aloha Scout likes this.
  2. Jul 27, 2016 at 10:04 PM
    xurusaibobx
    xurusaibobx Well-Known Member
    so long the exhaust exit pass the last operating window its legal. However by law if its louder then OEM then it can fall into a gray area. to loud you can get a ticket for loud exhaust ticket
    Check engine lights is not a safety inspection Item any inspector failing for a check engine light should be called out on it. demand them to call the city inspections office /AKA RECON their the same people who handle safety inspection over site as well.
    hawaii doesnt have emissions so they dont check exhaust in hawaii but technically you cant remove a CAT per Federal law - another hawaii GRAY AREA
  3. Jul 27, 2016 at 10:08 PM
    John taco
    John taco [OP] Well-Known Member
    JT - Johnny
    King of Prussia PA
    Try asking this part again,
    Any fellow members recommend a auto shop that is friendly for state safety inspection and/or a shop that can perform an alignment and provide a legal alignment within factory spec print out sheet for RECON? Got one or 2 shops but want to line up my options...
    thanks
  4. Jul 28, 2016 at 11:26 AM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    what's your options? @hacklerjason refers to American Tire in Kapolei if you're near the area. Scotty's and Island Brake and Alignment are two options a lot of folks have used. I've used American Tire and Island with really good results.
    hacklerjason and John taco[OP] like this.
  5. Jul 28, 2016 at 12:04 PM
    John taco
    JT - Johnny
    King of Prussia PA
    Those were both recommend to me, should suit the job :thumbsup:
  6. Jul 28, 2016 at 9:21 PM
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    Yea I send guys to either Kapolei or Mapunapuna american tire. Can do safeties but gotta be legal beagle.. For alignment they can get it where it will track well, steer well, and return to zero well, but might not be in spec for the vehicle. They will make a sheet that will get you through recon and give you another sheet with the real info
  7. Jul 28, 2016 at 9:37 PM
    hacklerjason
    Ewa Beach, HI
    By legal I mean lighting, recon, tint, etc... Anything that can be seen in the photo needs to be legit and justified on recon paperwork. The only thing I've personally seen slide is my tpms. I'm not sure how other places would treat the situation but I didn't have tpms sensors in my aftermarket wheels and they told me some places look for them. They told me over the phone to just put my stock wheels in the bed and they would pass me. I eventually made a tpms bomb and that was way better
  8. Jul 28, 2016 at 11:22 PM
    xurusaibobx
    better have them recheck with DOT. TPMS isnt a inspected item and can not be a item for failure on inspections.
  9. Jul 28, 2016 at 11:45 PM
    hacklerjason
    Ewa Beach, HI
    Actually sir, I think you better go recheck with DOT, which is federal, as in the FMVSS... Attached is a link for your review
    http://www.nhtsa.gov/cars/rules/rulings/tpmsfinalrule.6/tpmsfinalrule.6.html
    Also attached for your review, is the hawaii state safety requirements manual dated in 2013
    In this manual, at the middle of page 24, you will find a section called TIRES, and the first line states that "all tires used on public roads must conform to federal motor vehicle safety standards" ... That does not directly mention TPMS, but it does make mention of conformity to FMVSS which hawaii does follow... I can assure you that inspectors are supposed to be checking this and if they dont its because the interpretation of this exact manual leaves room for errors.
  10. Jul 28, 2016 at 11:47 PM
    hacklerjason
    Ewa Beach, HI
    Unless you mean to tell me the FMVSS doesn't apply to you?
    Just because the places you go to don't check, doesn't mean all places do the same poor inspection... I go to places where they do a proper inspection for state regulation as well as FMVSS... There lays the problem in itself.. I don't feel like spending another 400 for sensors in wheels I spent 1700 bucks on and wrapped in 1200 dollar rubbers.. These vehicles after 2007s phase in period are required to have them and the state is required to check for its presence and operation... Its up there with light colors and srs
  11. Jul 28, 2016 at 11:51 PM
    hacklerjason
    Ewa Beach, HI
    If you have your tpms light on, I highly advise you NOT to go to my referred locations, you will be failed there... I would think it would be obvious a tire/alignment shop that also does safeties would check for these things... But apparently some people are uninformed...
  12. Jul 28, 2016 at 11:53 PM
    hacklerjason
    Ewa Beach, HI
    Furthermore, when someone asks for help in a thread and you want to offer advise, please perform a fact check prior
    El Duderino likes this.
  13. Jul 28, 2016 at 11:57 PM
    hacklerjason
    Ewa Beach, HI
  14. Jul 29, 2016 at 2:32 AM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    John, I would also make an appointment in advanced. There is usually a long wait list anywhere you go.
  15. Jul 29, 2016 at 12:07 PM
    #35
    hacklerjason
    Ewa Beach, HI
    If you know what location you would like to go for american tire, let me know and I can schedule it for you
    John taco[OP] likes this.
  16. Jul 29, 2016 at 1:03 PM
    #36
    John taco
    JT - Johnny
    King of Prussia PA
    Thanks jason and seoulja99
    Jason I will PM u in future when time is ready, truck was just loaded up today.
    "Crawl mode"
    ACBAA4AA-19C5-4964-9C95-53AB410C321A_zps_aa68877701ea8ae77bcfe18d6f62d31a318e7712.jpg
    seoulja99 likes this.
  17. Jul 29, 2016 at 1:06 PM
    #37
    hacklerjason
    Ewa Beach, HI
    Yea let me know when you know.. I send a lot of business to them so I can get in the tight schedule pretty well..
  18. Jul 29, 2016 at 4:42 PM
    #38
    hacklerjason
    Ewa Beach, HI
    Since youre a bad source of information I found it relevant to correct you once again... The check engine lamp is grounds for failure, due to the fact we do not have emissions testing here... You will be failed on safeties per Hawaii code if any systems trouble lamps are illuminated, ABS, SRS, CEL, MIL, SES, etc... Please check yourself before telling anyone to check themselves... People like you are the reason bad information goes around causing much confusion on what the rules actually are... Post facts only please unless you like being made to look like an ass... And if you do not and I'm in the thread, I will correct you, and I will cite actual references for the TRUTH
    Please see page 28 of the Hawaii State Safety Inspection Manual
  19. Jul 29, 2016 at 4:44 PM
    #39
    hacklerjason
    Ewa Beach, HI
    Be advised that those in here looking for real information should double check anything @xurusaibobx says
  20. Jul 29, 2016 at 4:55 PM
    #40
    seoulja99
    E.J.
    Oahu
