Inspection
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtman 908, Jan 25, 2011.
  1. Jan 25, 2011 at 2:47 PM
    vtman 908
    vtman 908 [OP] Active Member
    4x4 Tacoma TRD
    Today, I went to get my 01 tacoma inspected and it failed inspection embarrassingly. The main reason was because the rear seals were leakin oil on the brakes. Is this a common thing that happens in the trucks?
  2. Jan 26, 2011 at 5:17 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    I believe so, here is a bump maybe others will chime it. I will you the best in getting it fixed and inspected. :)
  3. Jan 26, 2011 at 5:37 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2015 RAV4...c'mon lease, end already!
    3 Tacomas so far, waiting impatiently for my 4th
    I don't know if it's specifically common to Tacomas, but it's not uncommon in a 10 year old vehicle. It shouldn't be too big of a deal to get that taken care of.
  4. Jan 26, 2011 at 6:04 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    do you mean your wheel cyliders are leaking???
  5. Jan 26, 2011 at 6:22 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Ha mine were gone too, no biggie its a pretty easy job, just hope the brake lines come off and you will be good.
  6. Jan 26, 2011 at 8:21 AM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    This was the exact reason my 01 failed inspection as well. They wanted 1300 to fix it. I used my uncles mechanics (read: free) to do it, but I had to take the axle to toyota to press apart. Ended up costing 900. DO THE REAR DIFF BREATHER MOD.
  7. Jan 27, 2011 at 5:03 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    The main reason the seal goes is because the diff breather gets plugged or sealed, so its always a good idea to get under there and make sure the diff breather cap moves.
  8. Jan 27, 2011 at 5:16 AM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    I blew a seal on my 01, of course from pulling a camper 65-70mph through the mountains. It's an easy fix but remember to pick up a bottle of brake fluid if you diy, your gonna have to do quite a bit of bleeding when you get everything put back together.
  9. Jan 27, 2011 at 5:45 AM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    This can't be stressed enough. The diff has to breath ~ with heat the oil and gasses expand then cool contract.
    Want to fix it on the cheap?
    Most likely your seals are not bad but the internal pressure from poor venitng is just pushing oil past them. Pull the rear brakes and clean them up well (replace if necessary). Clean the drum / backing plate and around the rear hub. DO the breather mod and then go for reinspect. Damaged seals generally only come with age (not likely) / dirt mud contamination (still rare on somthin this new) / or bad bearings (again not likely) .
    How were your brakes before inspection? How did the feel? How did they stop? Good / Good = clean and go.
    **** One note of caution !!!! Often brake shoe replacment is necessary as oil gets absorbed into the friction material. Dry shoes work better...
    On the other hand if you are thinking of this quick fix but doubt the conditon of your seals then just clean up the oil and drive it for a week or two then reinspect. Some auto cross guys have ben known to grease the rear brakes to vary brake proportioing in stock classes that do not alow adjustable units. Even with those cars the grease is only a temporary fix before the brakes come back to regular force.
    I have a fleet of 20+ year old vehicles that tow up to 10k# hwy and see heavy mud with original seals and no leak.
