instal rear diff. on a 2wd? and best tire size, for best MPG?
Discussion in 'Off-Roading & Trails' started by volcomig, Feb 18, 2013.
  1. Feb 18, 2013 at 5:46 PM
    volcomig
    volcomig [OP] Well-Known Member
    miguel
    canada
    2wd sr5
    2.75 inch lift, Bigger tires, bull bar and backrack
    Hi Tacoma owners, I Just bought a 2wd access cab sr5 2009(My first pickup). I got it 2wd because of the fuel economy. Found the wheels too small and the rims ugly and came very low too. I lifted it 2.75inches and got mags with motomaster 265/75 R16 off road tires. My fuel economy went down in a rush. And the front tires are rubbing. Can tire brand affect mpg? What is a good tire size for a good look and good fuel economy (Original 15inches are too small).
    I wondered if after all a 4wd would have given me the same mpg as now? Anyways I have the truck and gonna stay with it. I want to go off road.But the truck has no rear lock. Any suggestions or previous experiences? how much would it cost? does it affect MPG? Mine has the LSD, Is it any good off road? what Does it do? Sorry if theres too many questions, I'm new to the forum and happy it exists :)
  2. Feb 18, 2013 at 5:54 PM
    cgs2k2
    cgs2k2 old man
    What is the year of your truck? 2009?
    The Load Range of your tire will change the weight, and thus, effect your gas milage.
    A passenger (P rated) tire will generally weight significantly less than an E rated LT (light truck) tire.
    265/75r16 shouldn't rub even on an unlifted pre-runner. Are you sure you're truck is a prerunner and not a regular 2wd?
    15 inch wheels will not work on a prerunner tacoma. The brakes will not clear.
    Getting a locking rear differential will not effect gas milage because you will only use it (lock the rear) when you are stuck or think you may get stuck. Driving around the street, the rear will not be locked, and you will get the same MPG you get now.
    As far as lockers, you can get an ARB air locker for around $900 USD.
  3. Feb 18, 2013 at 6:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Adding a locker won't affect MPG. It acts as an open differential until the locker is engaged.
  4. Feb 18, 2013 at 7:01 PM
    volcomig
    miguel
    canada
    2wd sr5
  5. Jun 6, 2013 at 12:56 PM
    Mickey
    Mickey Member
    Michael
    Westerly, RI
    `don't have one
    Wheels & tires are unsprung weight i.e. the vehicle is sprung; the tires & wheels are not.
    Unsprung weight hurts acceleration and gas-mileage, badly. For acceleration, that unsprung weight must be rotated, which takes energy i.e. power i.e. gas. Even cruising (e.g. for gas-mileage) wheels and tires must be spun.
    `don't believe me? Imagine spinning a donut on a pole; now, put a wheel and tire on the pole ... and spin it. Which requires more effort (energy ... gas)? Look at the manufacturer and EPA gas mileage configurations. Which wheel & tire combination shows the greatest gas mileage? ... the smallest!
    The less unsprung weight, the better - for acceleration & gas-mileage. Smaller diameter wheels and tires make for faster acceleration and greater gas mileage. Those monster wheels and tires just slow everything down. `sorry; that's just physics.
    While we're at it, the greatest aerodynamic drag on a vehicle is the air that gets UNDER it ... and bounces up and down between the ground and the vehicle. That's why race cars are built as low as possible without touching the ground. The higher the truck, the worse the gas-mileage! The more the truck is lifted, the worse the cruising gas-mileage will be.
  6. Jun 6, 2013 at 1:03 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  7. Jun 6, 2013 at 1:04 PM
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    Hey man to save time typin.... I've done all of that and get about 24-26 mpgs
    32" tires
    rear diff 4.10 gears w/ARB air locker
