Install a tach on a 2.7l??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Str8Flexin, Feb 19, 2015.
  1. Feb 19, 2015 at 12:48 PM
    Str8Flexin
    Str8Flexin [OP] Well-Known Member
    SoCal
    1998 Taco SAS linked Crawler
    Lots of stuff
    On my 98 2.7l 5 speed I am trying to put in a tachometer and oil pressure gauge. Does anyone have pics or instructions on where to tap this in at????
    Thanks
  2. Feb 19, 2015 at 1:07 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    cant help you with the connections but im curious, don't you already have a tach right there next to your speedo?
    I suggest you add a triple gage set so you get oil pressure, engine temp, and voltage or amp gage set.
    the temp gages we have are useless crap and its good to know the "real" engine temperature you are running and if your charging system is working ok.
  3. Feb 19, 2015 at 2:14 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  4. Feb 19, 2015 at 2:33 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    For the oil pressure gauge, If it's mechanical, find your oil pressure sending unit.
    Remove the sending unit and install a "T" fitting back in it's place. You can then plumb in your line for the pressure gauge and also retain the pressure sending unit for the idiot light.
    If it's electrical, I'm not sure.
  5. Feb 19, 2015 at 2:42 PM
    keakar
    karl
    louisiana
    if its electrical its the same thing you just put a tee fitting and hook your sending unit on one side and the gages sending unit on the other side.
    I strongly suggest never using a mechanical oil pressure gage, if you ever see what happens to the truck when a line breaks or leaks you will never want one either. people say they never heard of one leaking or breaking before but it only takes one time to ruin everything inside your truck.
  6. Feb 20, 2015 at 11:45 AM
    Str8Flexin
    SoCal
    Lots of stuff
    Ya i bought a 2 pod pillar mount. No it is the completely base model so it only has the speedometer, fuel guage, and temperature gauge.
