install coilovers
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Sep 19, 2009.
  1. Sep 19, 2009 at 2:09 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey guys I was wondering I'm going to get the toytec ultimate lift so coilovers.....is it easy to install them yourself or should I have someone else put them on. Has anyone put them on and everything was okay after that.
  2. Sep 19, 2009 at 2:13 PM
    Trdman98
    Trdman98 Member
    98 tacoma 4x4 6"
    3" body, Toytec Coilovers, Dakars, Bilsteins, 33"BFGs, Intake, Exhaust
    great kit and very easy install
  3. Sep 19, 2009 at 2:15 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Me and a buddy put my Icons on our selves. Easy stuff, just need the tools and COIL COMPRESSOR! Run by a Schucks or Kragan. They will let you barrow a coil compressor. You put a deposit down, but then get it all back when you return it. Best of luck!!!:D
  4. Sep 19, 2009 at 2:20 PM
    socal19
    California
    Okay so it should be easy right I can get all the tools and jack stands I think I saw a link on the suspension part that chris 4x4 put up on how to take off the coils..........isn't it just to unbolt 3 bolts up top and remove the whole coil out and just put the new ones on the same way........and how much do I torque them too
  5. Sep 19, 2009 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I sent you a PM with all the info needed. :)
