INSTALL HOW TO---BAMF 100% bolt on slider
Discussion in 'Armor' started by frizbal, Apr 26, 2015.
  1. Jun 15, 2015 at 11:28 AM
    frizbal
    frizbal [OP] Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Ya, the cross member straight flange almost need to be a little longer. The bolt hole is slotted, but you can't use any of the benefits of the slot as you are at the very end of it even with the c-clamp.
  2. Jun 18, 2015 at 2:33 PM
    mruseless
    mruseless Member
    Nothing yet
    Looks nice!
    Is your Taco lifted? Looks like not much if at all.
  3. Jun 18, 2015 at 2:36 PM
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    At that time I only had the TSB leaf pack and billy's up front at 1.75. Since then I've added a leaf pack in the rear which gave me about 1.5" more to regain my rake. Here's another pic of the sliders in use, and with the rear pack installed.
  4. Jun 18, 2015 at 2:40 PM
    mruseless
    mruseless Member
    Nothing yet
    Thanks. I'm a new Tacoma owner, and looking at getting at least a leveling kit. Wife doesn't want it lifted so trying to find something in the middle :)
  5. Jun 18, 2015 at 3:25 PM
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    If that's all you are wanting, the Billstein 5100s really are your best option. You can put a spacer on the front too if all you want to do it level it out. A lot of people frown on it on here, but this place is oriented around the more serious offroad-er. Spacers are great for simply adding a little lift if you are a city driver. I personally would've gone to the Billesteins anyway as I like the ride change with the new shocks.
  6. Jun 18, 2015 at 9:40 PM
    mruseless
    mruseless Member
    Nothing yet
    I understand the bias toward more serious off roading (which I may get to someday but I'm not there yet). I'll do some searches here to find the pros/cons of lifts vs. spacers.
  7. Jun 19, 2015 at 6:34 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    No pros with spacers.
  8. Jul 28, 2015 at 11:17 PM
    _JNM_
    _JNM_ Member
    2015 Black Tacoma TRD OR
    None yet, plenty to come
    Quick question about the bolt on vs. weld on. Is there any concern with the bolts/nuts rattling off or vibrating off? Would it be recommended to use some type of locktite to prevent it? Personally I don't plan on taking them off once installed, so the other question is can I find a welder to weld these on for the price difference between the weld-on vs. bolt on...
  9. Jul 29, 2015 at 3:54 AM
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Do the bolts rattle off your cross member, fuel line rails, or differential housing? Not being snarky, just making a point. Torque the bolts and you'll be ok. Not sure about welding costs, but you'd probably come in the same with extra shipping cost and material of the bolt on. Just depends if you want to weld the frame.
  10. Nov 27, 2015 at 11:11 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Sub'ed for when I get the set I ordered yesterday on the Thanksgiving Sale!
    GHOST SHIP likes this.
  11. Nov 27, 2015 at 9:05 PM
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    That's when I ordered mine ! Let me know if you have any questions during install.
  12. Nov 27, 2015 at 9:21 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  13. Dec 12, 2015 at 9:12 AM
    Tee Arghhhhhh Dee
    Tee Arghhhhhh Dee is typing...
    Jay
    Bay Area
    2011 SW DCSB 4x4 4.0L V6 Manual
    Stuff
    Did you have trouble with the cross arm bolt? Mine won't budge and its starting to strip even with a 9/16 socket.
  14. Dec 12, 2015 at 9:22 AM
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    I did. The "wing" that extends on the bottom needs to be ever so slightly longer, or slotted more. I had to clamp the sides of the frame and slider plate to push it more over the hole. Then put a jack on the bottom side to flatten out the "wing" more. It gave me about 1!8" more clearance on that bolt to make it go in. Mine started to strip too.
  15. Dec 12, 2015 at 9:28 AM
    #35
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    This is where I talk about it with the picture
  16. Dec 12, 2015 at 9:30 AM
    #36
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Wait.... Are you talking installing or first removal?
  17. Dec 12, 2015 at 9:30 AM
    #37
    Tee Arghhhhhh Dee
    Jay
    Bay Area
    Stuff
    Thanks, I can't even get the bolt loose and its starting to strip, going to have to go get an extractor socket. Did you end up replacing the bolts with longer ones?
  18. Dec 12, 2015 at 9:30 AM
    #38
    Tee Arghhhhhh Dee
    Jay
    Bay Area
    Stuff
    First removal.
  19. Dec 12, 2015 at 9:32 AM
    #39
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Ahhh ok. I got ya. It was tight, but no major issues. I hit it with some PB blaster. I did replace the original bolt with a longer one though.
  20. Dec 12, 2015 at 9:33 AM
    #40
    Tee Arghhhhhh Dee
    Jay
    Bay Area
    Stuff
    What length did you go to? Might as well do that as well while I'm at it.
