install kc daylighters wiring
Discussion in 'Lighting' started by xc182, Jan 8, 2014.
  1. Jan 8, 2014 at 5:51 PM
    xc182
    xc182 [OP] Member
    2002 SR5 4x4 4 cyc
    stock
    I know this subject has been beat to death but im no master electrician so I wanted to double check. I bought a brush guard for my truck so I could mount some driving lights. My gf bought me some 130 watt kc daylighter driving lights for christmas. The instructions are straight forward but I wanted to tie the kc lights into my highbeams on the truck. This will be a switched setup. What wire do I need to tie into from my switch going to the highbeams? Color of the wire and best location to tie into it would be great! It seems that people come through the firewall at the grommet for the ebrake, any other good spots? Thanks in advance for any tips or advice :humble:
  2. Jan 8, 2014 at 5:54 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Do you want to be able to turn the lights on manually and have the option of on with high beams?
  3. Jan 8, 2014 at 6:00 PM
    xc182
    xc182 [OP] Member
    2002 SR5 4x4 4 cyc
    stock
    I believe the way the instructions read, you have to flip the switch to on in order for the daylighters to be able to come on while im using the highbeams. That make any sense? And this is for an 2002 sr5 with the 2.7l if it makes any difference. Thank you
  4. Jan 8, 2014 at 8:22 PM
    2000GTacoma
    Snow Hill NC
    I assume the kit includes a relay that the high beams will control. I cannot remember exactly which wire but if you turn you high beams on and have a volt meter you can flip the high beams and test the plug that plugs into the light bulb in your headlight then trace that wire and just use a t tap or slice it. Solder would be the best way but that's your call.
  5. Jan 9, 2014 at 4:05 AM
    xc182
    xc182 [OP] Member
    2002 SR5 4x4 4 cyc
    stock
    The relay says no:2x20a/14vdc. Dc12v. Wiring also has a 25amp fuse for the power supply line going to the battery and a 3amp fuse for thenwhite wirengoing from the switch to the highbeam wire
