Install shim right from start? 3" rear lift
Discussion in 'Suspension' started by DVexile, May 8, 2015.
  1. May 8, 2015 at 7:54 AM
    DVexile
    DVexile [OP] Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    I'm planning out my suspension, likely ICON coilovers in the front at around 2.5" of lift with aftermarket UCAs. For the rear All Pro Expedition leafs and ICON 2.0 RR. I always have a load of at least 400 lbs in the back so that will put the Expos at about 3" lift at the max, a bit lower when fully provisioned for a long camping trip.
    It seems like many people end up needing a shim with a rear lift like that and no one is ever really hurt by a shim (unless they install it backwards of course). Given the hassle of install I'm thinking I should just install a shim at the same time I do the rest of the rear suspension. Obviously I can measure driveline angles afterwards and change plans if vibes develop, but it seems like the best starting point is to just put a shim in as that makes it the most likely I won't have to mess around with the rear again.
    Sounds thinking on my part? Stupid idea? (If so, why is it dumb!)
    Thanks!
  2. May 8, 2015 at 8:02 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I always just put 3 degree shims in, and a carrier bearing drop kit. Never have any vibes.
    DVexile[OP] likes this.
  3. May 8, 2015 at 8:12 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I didn't do the shim from the start. I did, however, install the CB drop and haven't had issues. I started to notice a vibe from 60-65 mph so I might have to do the shims soon..
  4. May 8, 2015 at 8:20 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Geek is in the houseeeeeeeeeeeeeeee
  5. May 8, 2015 at 8:21 AM
    geekhouse23
  6. May 8, 2015 at 8:25 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Could be your duratracs too...I never had a vibes when lifted on stock tires...now with duratracs I feel some vibs at around the same speed, but it's coming from the tires...they had to rebalance them twice already, it improved much
  7. May 8, 2015 at 8:32 AM
    geekhouse23
    Thanks Flow. I'll have to look. I only noticed it coming back from the Badlands last Sunday. At least the alignment wasn't off haha :eek:
  8. May 9, 2015 at 1:49 PM
    Softtacosupreme
    Softtacosupreme Well-Known Member
    Where can you get said CB drop? Thanks. Also, is there a specific shim? I googled 3* shim and it came up with a ton.
    BR63600 likes this.
  9. May 9, 2015 at 1:51 PM
    Softtacosupreme
  10. May 9, 2015 at 1:52 PM
    geekhouse23
  11. May 9, 2015 at 1:54 PM
    Softtacosupreme
    Awesome, thanks a lot for that!
  12. May 11, 2015 at 11:03 AM
    DVexile
    Ken
    Thanks for the replies guys! I think I'm going to plan on doing a 3* shim during the spring install. Seems like it could only help. I'll measure angle and see if I have a vibe and decide if a CB drop is in order too at that point. Can always do the CB drop later easily, but seems like doing the shim while doing the springs makes sense.
    Softtacosupreme likes this.
  13. May 12, 2015 at 4:15 PM
    Softtacosupreme
    I was thinking along the same lines as you. Do the shims first, then if needed CB drop after just because that'd be easy.
  14. May 12, 2015 at 4:24 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I did 5100's all around with an AAL in the rear with 3* shim and I've had no issues for over 50k miles. I did not do a cb drop or anything.
  15. May 12, 2015 at 4:26 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  16. May 14, 2015 at 6:51 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Any updates DVexile? Ordered my OME kit with Dakars and plan on doing the 3 deg shim from toytec (bought through wheelers). I'm not homing that the centre pin on the Dakars works with the kit. Does the protrusion in the pin just seat into the hole in the shim or do you have to remove the shim and reattach with the shim in place?
  17. May 16, 2015 at 7:52 AM
    DVexile
    Ken
    No updates from me, I'll be doing the install in a few months. At this point I'm planning on doing the shim from the start - hopefully I won't then have to take it out!
