Install time of the TRD lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beaverpelt, Jun 15, 2023.
  1. Jun 24, 2023 at 1:09 PM
    #41
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Do yourself a favour and grab the 5100's and a 1" block for the rear. That is basically the TRD kit in a nut shell at almost half the cost. Even the stock Off Road Bilsteins are a good ride, but the 5100s are a bigger better shock with a 2" lift, and eliminates the OEM brake dive.
    But if your planning to ad a lot of weight in the rear, then skip the block and get an add a leaf. Either way, will give you great results.
    You won't be disappointed.
  2. Jun 24, 2023 at 1:15 PM
    #42
    beaverpelt
    beaverpelt [OP] Well-Known Member
    STL
    2023 Tacoma TRD OR
    I ordered the pre-assembled 6112's set at 1.7" and 5100 rears from Shock Surplus. I also ordered the 1/2" TRD Pro lift blocks.
    Tocamo[QUOTED] likes this.
  3. Jun 24, 2023 at 3:41 PM
    #43
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Solid advice!
    So what are Pro lift blocks? Why 1/2 inch. A simple one inch bolt on block is perfect.
  4. Jun 24, 2023 at 3:46 PM
    #44
    Bishop84
    Bishop84 Well-Known Member
    1" block is the sweet spot. 1/2" will work, but 2 and 1 would sit better. 2 and 1/2 will sit closer to level.
  5. Jun 24, 2023 at 4:11 PM
    #45
    beaverpelt
    STL
    2023 Tacoma TRD OR
    I may go 1" but I want to see how the 1/2" looks first.
  6. Jun 24, 2023 at 5:39 PM
    #46
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My memory may be off. It may be a 1/2" block in the rear to give you 1". I cant remember now, and I'm too lay to look, but I basically I have the 2/1" lift, which is exactly what the TRD kit consists of.
  7. Jun 25, 2023 at 3:31 AM
    #47
    VaToy
    Parts Unknown
    Its different in the front. A one in rear block will just be a one inch of lift.
  8. Jun 26, 2023 at 3:36 PM
    #48
    GMGreen
    GMGreen Member
    22 Army Green Tacoma Off-Road
    Trail Edition Wheels, interior LED,
    Is SS legit? Seems too good to be true. I just want to do a 2F+1.5R lift.
  9. Jun 26, 2023 at 7:22 PM
    #49
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  10. Jun 26, 2023 at 7:33 PM
    #50
    Bhett28
    Bhett28 Member
    WI
    2023 Lime TRD Sport
    Took the dealer a whole day to install mine
