Install wench to the bed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joedi, Nov 12, 2012.
  1. Nov 14, 2012 at 10:09 AM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    Yeah............I go with the blonde wench model too.
  2. Nov 14, 2012 at 10:17 AM
    badger
    badger Well-Known Member
    07 SR5
    Um,..... I think that wench comes with synthetic line :rolleyes:
  3. Nov 14, 2012 at 10:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I still think the hitch mounted game hoist is the way to go. Lift the animal up, get it heading into the bed and pull it in as you let the hoist out. You'd never be moving the animal's entire weight and it's easily removable. Otherwise, a custom bracket that uses the bed bolts to the frame wouldn't be hard to fabricate. I would think you'd want some sort of roller at the tailgate though.
  4. Nov 14, 2012 at 10:35 AM
    nat
    2007 DC SB Tacoma
    Jesus you guys over complicate shit.
    A simple steel tube, with a good wall thickness, spacers underneath, bolted at the front of the bed using the existing bed bolts. Mount your winch to that. Run a line from your battery or put an extra battery in the bed.
    Done
    Cheap
    Easy
    Can be made by most anybody with a drill press
    Buy a cheap winch if you need to save money
    Go hunt
    Enjoy your venison.
    /thread
  5. Nov 14, 2012 at 12:35 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My name is OZ-T , and I approve this message
  6. Nov 14, 2012 at 1:19 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    :thumbsup: and for even cheaper you could use a come-a-long instead of a winch.
  7. Nov 14, 2012 at 1:44 PM
    nat
    2007 DC SB Tacoma
    Exactly, put an eye bolt in the tube.
    A harbor freight ATV winch is pretty damned cheap and it doesn't matter if it dies one day.
  8. Nov 14, 2012 at 1:46 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    very true. you could get their warranty and swap it out real quick if it shits out on you.
  9. Nov 14, 2012 at 1:57 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
  10. Nov 14, 2012 at 1:59 PM
    Pugga
    Massachusetts
    I still think you should put a roller on the end of the tailgate or the bed, whatever the cable will be dragging over to protect both the cable and the tailgate. On the cheap, a piece of PVC pipe cut in half will work for a while as a sliding surface.
  11. Nov 14, 2012 at 2:09 PM
    mooker82
    mooker82 Well-Known Member
    What about mounting a boat trailer winch (the hand crank kind like you use to pull the boat onto the bunks). Cheap and strong enough to pull up most anything that will fit in the bed.
  12. Nov 14, 2012 at 2:26 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    install front d-loops..stretch a cable across and attach a pulley..then hand winch from outside the truck?
  13. Jun 2, 2020 at 11:05 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ive read what U want
    what some say
    the hitch is only weight rated in ONE(1) !! axis
    if U were to p/u 500 ........750...... maybe even 1000lbs
    far exceeding the hitch capacity
    U could plate the bed
    actually put 1/2 plate top & bottom
    sandwich the composite bed between
    stil the bed might fail...........full sized pick upz with sheet metal no better
    attaching to frame NO great assurance
    the Best rigs are ' center mounted ' usually between the front / rear axles
    neccesitating working off the side or having quite some length in the boom itself
    yes for years ' corner mounts ' were built & used
    trucks turned over quite a bit
    ive run 60ton winches & cranes for years
    no less the more angle U get from vertical
    the longer the boom
    the LESS U CAN LIFT SAFELY !!
    its the ' Leverage ' another response mentioned
    sometime 4- 5X or more
    no less U dont mention accomodation of ' Stiff Legs '
  14. Jun 2, 2020 at 11:14 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    This thread is from 8 years ago, I have to assume he got it figured out by now..
    Muddinfun and tcjacado like this.
  15. Jun 2, 2020 at 11:22 AM
    #35
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    Road Dogg vs necroposts:
    .... RIP the attitude era.
    spencermarkd likes this.
